Gazebo’s mesh loading library doesn’t support glTF2 and FBX mesh loaders. There are two ways to extend the capabilities of the Gazebo’s mesh loading system, (A) Using an external open-source library or (B) Writing glTF2 and FBX mesh loaders consistent with the current approach.
An initial analysis is required to decide which approach is better. I am planning to generate such analysis in the next couple of days, so any idea is welcome. The main aspect of the analysis will be around:
- Maturity analysis
Which file types are supported by the external library, development history of the external library. - Complexity analysis
Complexity comparison of possible external libraries and developing new glTF2 and FBX mesh loaders similar to existing approach. - Testing difficulty analysis
Testing difficulty comparison of the possible external libraries versus the existing approach. - Required time to Implement vs Integrate
You can also follow it from the github
