This is a project to provide set of system plugins for simulating surface waves and the dynamics of marine surface craft. The original plugins were developed for legacy Gazebo and are being ported to Ignition. The target render system is Ogre2 and the plugins should work on both Ubuntu and macOS (using Metal).
The libraries are GPL because one of the core components used to implement the vehicle dynamics is CGAL and the ocean simulation uses FFTW to generate the surface waves. It would be possible to find alternatives for both components, but replacing CGAL would be a substantial undertaking.
The migration is being tracked here: Migrate to Ignition Gazebo · Issue #15 · srmainwaring/asv_wave_sim · GitHub and has progressed to the stage where there is an initial version that provides the main components that allow some of the example models that were used in Gazebo11 to be run on Ignition Garden.
There is a lot more to do, especially regarding optimisation, parameter setting and general usability. The details of the approach and references are described in the project README.
Options 1 and 2 are quite similar and really only differ in that 2 factors out common code for defining custom shaders. At present multiple visual plugins are not supported which leaves option 1 as the approach using Ogre1 type materials and where the wave generation code is also in the shader.
In my case the vertex positions are calculated on the CPU, so I need a fast way to get these into the GPU. One way would be to use GPU code for the FFT wave generation as well as for sinusoidal and trochoidal waves. There is a OpenCL option for generating the waves, but it uses a read-back from the GPU into CPU vertices (for the physics and the visual), and then ships back to the GPU as an Ogre1 material for visuals. In principal that FFT shader code could be used in a render pass directly for the visuals, but I’m someway way away from understanding the Hlms and compositor systems well enough to implement that.
The other options 4, and 5 that use a custom Hlms could be seen as intermediate steps to using shader based wave generation. The Ogre2 examples for these are quite advanced and I’m slowly working through the methods to see how they can be adapted. Most of the wave generation code I use displaces the vertices in the xy-plane as well vertically, and I’m not yet sure whether the logic for cell tiling used in Terra can relax it’s assumptions about a fixed planar grid. With periodic boundary conditions it should tile correctly but that would all need to be worked through.
I’ve managed to get the MBZIRC project built on macOS running Ignition Gazebo and ROS2 Galactic. With a little bit of tuning it’s working and it’s very useful to have a baseline.
As a side note: it would be nice to be able to control the thruster plugin for the USV using ArduPilot - this should be possible with some tweaks to the ardupilot_gazebo system plugin.
