Hello All, Have tried to execute empty sdf and while click play button it moves between play and pause, not able to continue from here. using Virtual box with 6GB RAM, ROS2, DOME. Please suggest.
Hi @Mani, https://answers.gazebosim.org/. Is a better place for this kind of technical question. Please post the question there and someone should help you. This forum is for announcements and high-level discussions.
In any case, make sure you don’t have any Ignition processes running in the background before you run a new one. Having 2 servers running at the same time, one paused and the other unpaused, can cause the problem you’re seeing.
