Moving an actor with ROS2 utilizing a joystick
Hello, I have been trying to move an actor with a Joystick with ROS2 and Gazebo Sim (harmonic) however I am having difficulties. Firstly to simplify the problem I have attempted to create a custom plugin to modify the position of the actor but the attempt has been unsuccessful, only have been able to extract information for the simulation but when I try to modify the agent’s position it just does not respond.
As template for the plugin I have used this: ros_gz_project_template/ros_gz_example_gazebo at main · gazebosim/ros_gz_project_template · GitHub
This is the code of the plugin
header:
         * Copyright (C) 2022 Open Source Robotics Foundation
         * Licensed under the Apache License, Version 2.0 (the "License");
         * you may not use this file except in compliance with the License.
         * You may obtain a copy of the License at
         *     http://www.apache.org/licenses/LICENSE-2.0
         * Unless required by applicable law or agreed to in writing, software
         * distributed under the License is distributed on an "AS IS" BASIS,
         * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
         * See the License for the specific language governing permissions and
         * limitations under the License.
        #ifndef ROS_GZ_EXAMPLE_GAZEBO__FULL_SYSTEM_HH_
        #define ROS_GZ_EXAMPLE_GAZEBO__FULL_SYSTEM_HH_
        // The only required include in the header is this one.
        // All others will depend on what your plugin does.
        #include <gz/sim/EventManager.hh>
        #include <gz/sim/System.hh>
        #include <gz/sim/components/Name.hh>
        #include <gz/sim/Actor.hh>
        #include "rclcpp/rclcpp.hpp"
        namespace ros_gz_example_gazebo
          // This is the main plugin's class. It must inherit from System and at least
          // one other interface.
          // Here we use `ISystemPostUpdate`, which is used to get results after
          // physics runs. The opposite of that, `ISystemPreUpdate`, would be used by
          // plugins that want to send commands.
          class FullSystem:
            public gz::sim::System,
            public gz::sim::ISystemConfigure,
            public gz::sim::ISystemPreUpdate,
            public gz::sim::ISystemUpdate,
            public gz::sim::ISystemPostUpdate,
            public gz::sim::ISystemReset
            /// \brief Constructor
            public: FullSystem();
            // Plugins inheriting ISystemConfigure must implement the Configure
            // callback. This is called when a system is initially loaded.
            // The _entity variable contains the entity that the system is attached to
            // The _element variable contains the sdf Element with custom configuration
            // The _ecm provides an interface to all entities and components
            // The _eventManager provides a mechanism for registering internal signals
            public: void Configure(
                        const gz::sim::Entity &_entity,
                        const std::shared_ptr<const sdf::Element> &_element,
                        gz::sim::EntityComponentManager &_ecm,
                        gz::sim::EventManager &_eventManager) override;
            // Plugins inheriting ISystemPreUpdate must implement the PreUpdate
            // callback. This is called at every simulation iteration before the physics
            // updates the world. The _info variable provides information such as time,
            // while the _ecm provides an interface to all entities and components in
            // simulation.
            public: void PreUpdate(const gz::sim::UpdateInfo &_info,
                        gz::sim::EntityComponentManager &_ecm) override;
            // Plugins inheriting ISystemUpdate must implement the Update
            // simulation.
            public: void Update(const gz::sim::UpdateInfo &_info,
            // Plugins inheriting ISystemPostUpdate must implement the PostUpdate
            // callback. This is called at every simulation iteration after the physics
            // simulation.
            public: void PostUpdate(const gz::sim::UpdateInfo &_info,
                        const gz::sim::EntityComponentManager &_ecm) override;
            // Plugins inheriting ISystemReset must implement the Reset callback.
            // This is called when simulation is reset/rewound to initial conditions.
            public: void Reset(const gz::sim::UpdateInfo &_info,
            public: std::shared_ptr<rclcpp::Node> rosnode;
            private: gz::math::Pose3d actorPose;
        #endif
CPP script:
    // We'll use a string and the gzmsg command below for a brief example.
    // Remove these includes if your plugin doesn't need them.
    #include <string>
    #include <gz/common/Console.hh>
    // This header is required to register plugins. It's good practice to place it
    // in the cc file, like it's done here.
    #include <gz/plugin/Register.hh>
    // Don't forget to include the plugin's header.
    #include "ros_gz_example_gazebo/FullSystem.hh"
    // This is required to register the plugin. Make sure the interfaces match
    // what's in the header.
    GZ_ADD_PLUGIN(
        ros_gz_example_gazebo::FullSystem,
        gz::sim::System,
        ros_gz_example_gazebo::FullSystem::ISystemConfigure,
        ros_gz_example_gazebo::FullSystem::ISystemPreUpdate,
        ros_gz_example_gazebo::FullSystem::ISystemUpdate,
        ros_gz_example_gazebo::FullSystem::ISystemPostUpdate,
        ros_gz_example_gazebo::FullSystem::ISystemReset
      FullSystem::FullSystem(){
          // Initialize ROS if it hasn't been initialized
          if (!rclcpp::ok())
              int argc = 0;
              char **argv = nullptr;
              rclcpp::init(argc, argv);
          // Create the ROS 2 Node
          rosnode = std::make_shared<rclcpp::Node>("FullSystem");
          // Example usage: print out a log message to verify the node was created successfully
          RCLCPP_INFO(rosnode->get_logger(), "FullSystem Node has been successfully created.");
    void FullSystem::Configure(const gz::sim::Entity &_entity,
      gzdbg << "ros_gz_example_gazebo::FullSystem::Configure on entity: " << _entity << std::endl;
    void FullSystem::PreUpdate(const gz::sim::UpdateInfo &_info,
      if (!_info.paused && _info.iterations % 1000 == 0)
        gzdbg << "ros_gz_example_gazebo::FullSystem::PreUpdate" << std::endl;
    void FullSystem::Update(const gz::sim::UpdateInfo &_info,
        gzdbg << "ros_gz_example_gazebo::FullSystem::Update" << std::endl;
      gz::sim::Entity entityActor = _ecm.EntityByComponents(gz::sim::components::Name("actor_walking"));
      gz::sim::Actor actor_ = gz::sim::Actor(entityActor);
      if (!_info.paused)
        gz::math::Pose3d actorPose = actor_.WorldPose(_ecm).value();
        gz::math::Vector3d positionAgent = actorPose.Pos();
        gzdbg << "Actor with Pose in X axis:" << positionAgent.X() << std::endl;
        RCLCPP_INFO(rosnode->get_logger(), "Human Agent with position in x-axis: %f", positionAgent.X());
        actorPose.Pos().X(positionAgent.X() + 0.01);
        actor_.SetTrajectoryPose(_ecm, actorPose);
    void FullSystem::PostUpdate(const gz::sim::UpdateInfo &_info,
        gzdbg << "ros_gz_example_gazebo::FullSystem::PostUpdate" << std::endl;
      if (!_info.paused)
    void FullSystem::Reset(const gz::sim::UpdateInfo &_info,
      gzdbg << "ros_gz_example_gazebo::FullSystem::Reset" << std::endl;
    }  // namespace ros_gz_example_gazebo
SDF file (world)
    <?xml version="1.0" ?>
      Try sending commands:
        gz topic -t "/model/diff_drive/cmd_vel" -m gz.msgs.Twist -p "linear: {x: 1.0}, angular: {z: -0.1}"
        ros2 topic pub /diff_drive/cmd_vel geometry_msgs/msg/Twist "{linear: {x: 5.0, y: 0.0, z: 0.0}, angular: {x: 0.0, y: 0.0, z: -0.1}}"
      Listen to odometry:
        gz topic -e -t /model/diff_drive/odometry
        ros2 topic echo /model/diff_drive/odometry
    <sdf version="1.8">
      <world name="demo">
          filename="gz-sim-physics-system"
          name="gz::sim::systems::Physics">
          filename="gz-sim-sensors-system"
          name="gz::sim::systems::Sensors">
          <render_engine>ogre2</render_engine>
          filename="gz-sim-scene-broadcaster-system"
          name="gz::sim::systems::SceneBroadcaster">
          filename="gz-sim-user-commands-system"
          name="gz::sim::systems::UserCommands">
          filename="BasicSystem"
          name="ros_gz_example_gazebo::BasicSystem">
          filename="FullSystem"
          name="ros_gz_example_gazebo::FullSystem">
        <light name="sun" type="directional">
          <cast_shadows>true</cast_shadows>
          <pose>0 0 10 0 0 0</pose>
          <diffuse>0.8 0.8 0.8 1</diffuse>
          <specular>0.2 0.2 0.2 1</specular>
          <attenuation>
            <range>1000</range>
            <constant>0.9</constant>
            <linear>0.01</linear>
            <quadratic>0.001</quadratic>
          </attenuation>
          <direction>-0.5 0.1 -0.9</direction>
        </light>
        <actor name="actor_walking">
          <skin>
              <filename>https://fuel.gazebosim.org/1.0/Mingfei/models/actor/tip/files/meshes/walk.dae</filename>
              <scale>1.0</scale>
          </skin>
          <animation name="walk">
              <interpolate_x>true</interpolate_x>
          </animation>
          <script>
            <loop>true</loop>
            <delay_start>0.000000</delay_start>
            <auto_start>true</auto_start>
            <trajectory id="0" type="walking">
              <waypoint>
                <time>0</time>
                <pose>0 0 1.0 0 0 0</pose>
              </waypoint>
              <waypoint>
                    <time>2</time>
                    <pose>2.0 0 1.0 0 0 0</pose>
                </waypoint>
            </trajectory>
          </script>
        </actor>
        <model name="ground_plane">
                <plane>
                  <normal>0 0 1</normal>
                  <size>100 100</size>
                </plane>
                <plane>
                </plane>
                <ambient>0.8 0.8 0.8 1</ambient>
                <specular>0.8 0.8 0.8 1</specular>
        <model name="diff_drive">
          <self_collide>true</self_collide>
          <pose>10 10 0.35 0 0 0</pose>
          <include merge="true">
            <uri>package://ros_gz_example_description/models/diff_drive</uri>
            filename="gz-sim-joint-state-publisher-system"
            name="gz::sim::systems::JointStatePublisher">
            filename="gz-sim-pose-publisher-system"
            name="gz::sim::systems::PosePublisher">
            <publish_link_pose>true</publish_link_pose>
            <use_pose_vector_msg>true</use_pose_vector_msg>
            <static_publisher>true</static_publisher>
            <static_update_frequency>1</static_update_frequency>
            filename="gz-sim-odometry-publisher-system"
            name="gz::sim::systems::OdometryPublisher">
            <odom_frame>diff_drive/odom</odom_frame>
            <robot_base_frame>diff_drive</robot_base_frame>
      </world>
Hello community, found a short alternative which is modifying the pose of the actor. However this limits the visualization as there would not be any animation. Any ideas to synchronize the animation of an agent to the move accordingly?
Tried this but failed to do so:
  • Trying to use the class Actor [Gazebo Sim: Actor Class Reference] (failed, the SetAnimationTime, SetTrajectoryPose only works once)
  • There are no way to directly set a custom trajectory to an actor
Can you try doing this through components, see example in FollowActor system (used in follow_actor.sdf world. The Actor’s SetTrajectoryPose function does very similar thing but I think the difference is that it does not call ecm.SetChanged
Thank you @iche033 for the support given. Managed to make it work however still need to syncronize the animation of the movement (not too important at this point so it will go to the pile of ‘things to do later’)
