Hello Gazebo_community,
I am trying to make a drone with meshes and i want to controll it with Ros2-Controller (Keyboard)
just to make sure i am a beginner with it.
The problem i got is that i cannot controll my drone at all. i searched everywhere and tried everything i can but i could not find the problem.
Can someone help me to make it move at least in +Z Axis and -Z Axis so i can say i finally did something.
i am using Ubuntu Humble with Ros2 and Gazebo.
i hope i gave every needed details so someone can help me out.
rsp.launch.py:
import os
from ament_index_python.packages import get_package_share_directory
from launch import LaunchDescription
from launch.actions import DeclareLaunchArgument
from launch.substitutions import LaunchConfiguration
from launch_ros.actions import Node
from launch.substitutions import Command, PathJoinSubstitution
from launch_ros.substitutions import FindPackageSharedef generate_launch_description():
use_sim_time = LaunchConfiguration(‘use_sim_time’)pkg_path = FindPackageShare('my_bot') xacro_file = PathJoinSubstitution([pkg_path, 'description', 'robot.urdf.xacro']) robot_description_config = Command(['xacro ', xacro_file]) params = {'robot_description': robot_description_config, 'use_sim_time': use_sim_time} node_robot_state_publisher = Node( package='robot_state_publisher', executable='robot_state_publisher', output='screen', parameters=[params] ) return LaunchDescription([ DeclareLaunchArgument( 'use_sim_time', default_value='false', description='Use sim time if true' ), node_robot_state_publisher ])
launcher_sim.launch.py:
import os
from launch.actions import IncludeLaunchDescription, DeclareLaunchArgument, TimerAction
from launch.launch_description_sources import PythonLaunchDescriptionSource
from launch.substitutions import LaunchConfigurationdef generate_launch_description():
package_name = ‘my_bot’rsp = IncludeLaunchDescription( PythonLaunchDescriptionSource([os.path.join( get_package_share_directory(package_name), 'launch', 'rsp.launch.py' )]), launch_arguments={'use_sim_time': 'true'}.items() ) gazebo = IncludeLaunchDescription( PythonLaunchDescriptionSource([os.path.join( get_package_share_directory('gazebo_ros'), 'launch', 'gazebo.launch.py' )]), ) spawn_entity = Node( package='gazebo_ros', executable='spawn_entity.py', arguments=['-topic', 'robot_description', '-entity', 'my_bot'], output='screen' ) joint_state_broadcaster_spawner = Node( package="controller_manager", executable="spawner", arguments=["joint_state_broadcaster"], output="screen" ) velocity_controller_spawner = Node( package="controller_manager", executable="spawner", arguments=["velocity_controller"], output="screen" ) use_sim_time = LaunchConfiguration('use_sim_time') joy_params = os.path.join(get_package_share_directory('my_bot'), 'config', 'joystick.yaml') joy_node = Node( package='joy', executable='joy_node', parameters=[joy_params, {'use_sim_time': use_sim_time}], ) teleop_node = Node( package='teleop_twist_joy', executable='teleop_node', name='teleop_node', parameters=[joy_params, {'use_sim_time': use_sim_time}], remappings=[('/cmd_vel','/new_cmd_vel')] ) teleop_twist_keyboard = Node( package='teleop_twist_keyboard', executable='teleop_twist_keyboard', name='teleop_twist_keyboard', output='screen', remappings=[('/cmd_vel', '/new_cmd_vel')] ) return LaunchDescription([ rsp, gazebo, spawn_entity, TimerAction( period=5.0, actions=[joint_state_broadcaster_spawner] ), TimerAction( period=10.0, actions=[velocity_controller_spawner] ), DeclareLaunchArgument( 'use_sim_time', default_value='false', description='Use sim time if true', ), joy_node, teleop_node, teleop_twist_keyboard, ])
drone.urdf.xacro:
robot_description robot_state_publisher /home/alba/dev_ws/src/my_bot/config/rotor_controller.yaml<ros2_control name=“GazeboSystem” type=“system”>
gazebo_ros2_control/GazeboSystem
<joint name="base_to_b1"> <command_interface name="velocity"/> <state_interface name="velocity"/> </joint> <joint name="base_to_b2"> <command_interface name="velocity"/> <state_interface name="velocity"/> </joint> <joint name="base_to_b3"> <command_interface name="velocity"/> <state_interface name="velocity"/> </joint> <joint name="base_to_b4"> <command_interface name="velocity"/> <state_interface name="velocity"/> </joint>
</ros2_control>
rotor_controller.yaml:
controller_manager:
ros__parameters:
update_rate: 50
use_sim_time: true
joint_state_broadcaster:
type: joint_state_broadcaster/JointStateBroadcaster
velocity_controller:
type: velocity_controllers/JointGroupVelocityControllervelocity_controller:
ros__parameters:
joints:
- base_to_b1
- base_to_b2
- base_to_b3
- base_to_b4
joystick.yaml:
joy_node:
ros__parameters:
device_id: 0
deadzone: 0.05
autorepeat_rate: 20.0teleop_node:
ros__parameters:
axis_linear:
z: 4
scale_linear:
z: 2.0
scale_linear_turbo:
z: 5.0axis_linear: x: 0 scale_linear: x: 5.0 scale_linear_turbo: x: 10.0 axis_angular: yaw: 1 scale_angular: yaw: 5.0 scale_angular_turbo: yaw: 10.0 axis_linear: y: 3 scale_linear: y: 5.0 scale_linear_turbo: y: 10.0 enable_turbo_button: 1 require_enable_button: false
and just in case you need the log to make sure:
[INFO] [launch]: All log files can be found below /home/alba/.ros/log/2024-09-19-14-49-18-788212-alba-4163
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [robot_state_publisher-1]: process started with pid [4166]
[INFO] [gzserver-2]: process started with pid [4168]
[INFO] [gzclient-3]: process started with pid [4170]
[INFO] [spawn_entity.py-4]: process started with pid [4172]
[INFO] [joy_node-5]: process started with pid [4174]
[INFO] [teleop_node-6]: process started with pid [4176]
[teleop_node-6] [INFO] [1726750161.682192441] [TeleopTwistJoy]: Turbo on button 1.
[teleop_node-6] [INFO] [1726750161.682370041] [TeleopTwistJoy]: Linear axis x on 0 at scale 5.000000.
[teleop_node-6] [INFO] [1726750161.682422641] [TeleopTwistJoy]: Turbo for linear axis x is scale 10.000000.
[teleop_node-6] [INFO] [1726750161.682471641] [TeleopTwistJoy]: Linear axis y on 3 at scale 5.000000.
[teleop_node-6] [INFO] [1726750161.682518341] [TeleopTwistJoy]: Turbo for linear axis y is scale 10.000000.
[teleop_node-6] [INFO] [1726750161.682565141] [TeleopTwistJoy]: Linear axis z on 4 at scale 2.000000.
[teleop_node-6] [INFO] [1726750161.682612841] [TeleopTwistJoy]: Turbo for linear axis z is scale 5.000000.
[teleop_node-6] [INFO] [1726750161.682659641] [TeleopTwistJoy]: Angular axis yaw on 1 at scale 5.000000.
[teleop_node-6] [INFO] [1726750161.682956741] [TeleopTwistJoy]: Turbo for angular axis yaw is scale 10.000000.
[robot_state_publisher-1] [WARN] [1726750161.806138669] [kdl_parser]: The root link base_link has an inertia specified in the URDF, but KDL does not support a root link with an inertia. As a workaround, you can add an extra dummy link to your URDF.
[robot_state_publisher-1] [INFO] [1726750161.806511869] [robot_state_publisher]: got segment b1
[robot_state_publisher-1] [INFO] [1726750161.806995869] [robot_state_publisher]: got segment b2
[robot_state_publisher-1] [INFO] [1726750161.807079069] [robot_state_publisher]: got segment b3
[robot_state_publisher-1] [INFO] [1726750161.807158569] [robot_state_publisher]: got segment b4
[robot_state_publisher-1] [INFO] [1726750161.807236669] [robot_state_publisher]: got segment base_link
[robot_state_publisher-1] [INFO] [1726750161.807315069] [robot_state_publisher]: got segment cam
[robot_state_publisher-1] [INFO] [1726750161.807393269] [robot_state_publisher]: got segment land
[spawn_entity.py-4] [INFO] [1726750163.485488247] [spawn_entity]: Spawn Entity started
[spawn_entity.py-4] [INFO] [1726750163.490059849] [spawn_entity]: Loading entity published on topic robot_description
[spawn_entity.py-4] /opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/qos.py:307: UserWarning: DurabilityPolicy.RMW_QOS_POLICY_DURABILITY_TRANSIENT_LOCAL is deprecated. Use DurabilityPolicy.TRANSIENT_LOCAL instead.
[spawn_entity.py-4] warnings.warn(
[spawn_entity.py-4] [INFO] [1726750163.511889853] [spawn_entity]: Waiting for entity xml on robot_description
[spawn_entity.py-4] [INFO] [1726750163.548037562] [spawn_entity]: Waiting for service /spawn_entity, timeout = 30
[spawn_entity.py-4] [INFO] [1726750163.552380363] [spawn_entity]: Waiting for service /spawn_entity
[gzclient-3] Couldn't find a preferred IP via the getifaddrs() call; I'm assuming that your IP address is 127.0.0.1. This should work for local processes, but will almost certainly not work if you have remote processes.Report to the disc-zmq development team to seek a fix.
[gzserver-2] Couldn't find a preferred IP via the getifaddrs() call; I'm assuming that your IP address is 127.0.0.1. This should work for local processes, but will almost certainly not work if you have remote processes.Report to the disc-zmq development team to seek a fix.
[spawn_entity.py-4] [INFO] [1726750165.862268983] [spawn_entity]: Calling service /spawn_entity
[INFO] [spawner-7]: process started with pid [4321]
[gzclient-3]
[gzclient-3] libcurl: (6) Could not resolve host: fuel.ignitionrobotics.org
[spawn_entity.py-4] [INFO] [1726750166.805391196] [spawn_entity]: Spawn status: SpawnEntity: Successfully spawned entity [my_bot]
[INFO] [spawn_entity.py-4]: process has finished cleanly [pid 4172]
[spawner-7] [INFO] [1726750167.796919320] [spawner_joint_state_broadcaster]: waiting for service /controller_manager/list_controllers to become available...
[gzserver-2] [INFO] [1726750167.913570246] [gazebo_ros2_control]: Loading gazebo_ros2_control plugin
[gzserver-2] [INFO] [1726750167.948584454] [gazebo_ros2_control]: Starting gazebo_ros2_control plugin in namespace: /
[gzserver-2] [INFO] [1726750167.949257654] [gazebo_ros2_control]: Starting gazebo_ros2_control plugin in ros 2 node: gazebo_ros2_control
[gzserver-2] [INFO] [1726750167.968664058] [gazebo_ros2_control]: connected to service!! robot_state_publisher
[gzserver-2] [INFO] [1726750167.976233760] [gazebo_ros2_control]: Received urdf from param server, parsing...
[gzserver-2] [INFO] [1726750167.976625460] [gazebo_ros2_control]: Loading parameter files /home/alba/dev_ws/src/my_bot/config/rotor_controller.yaml
[gzserver-2] [INFO] [1726750168.034078373] [gazebo_ros2_control]: Loading joint: base_to_b1
[gzserver-2] [INFO] [1726750168.034458373] [gazebo_ros2_control]: State:
[gzserver-2] [INFO] [1726750168.034875573] [gazebo_ros2_control]: velocity
[gzserver-2] [INFO] [1726750168.035126073] [gazebo_ros2_control]: Command:
[gzserver-2] [INFO] [1726750168.035369373] [gazebo_ros2_control]: velocity
[gzserver-2] [INFO] [1726750168.035621373] [gazebo_ros2_control]: Loading joint: base_to_b2
[gzserver-2] [INFO] [1726750168.036117173] [gazebo_ros2_control]: State:
[gzserver-2] [INFO] [1726750168.036366973] [gazebo_ros2_control]: velocity
[gzserver-2] [INFO] [1726750168.036611973] [gazebo_ros2_control]: Command:
[gzserver-2] [INFO] [1726750168.037036873] [gazebo_ros2_control]: velocity
[gzserver-2] [INFO] [1726750168.037300074] [gazebo_ros2_control]: Loading joint: base_to_b3
[gzserver-2] [INFO] [1726750168.037549074] [gazebo_ros2_control]: State:
[gzserver-2] [INFO] [1726750168.037991274] [gazebo_ros2_control]: velocity
[gzserver-2] [INFO] [1726750168.038238174] [gazebo_ros2_control]: Command:
[gzserver-2] [INFO] [1726750168.038482574] [gazebo_ros2_control]: velocity
[gzserver-2] [INFO] [1726750168.038944574] [gazebo_ros2_control]: Loading joint: base_to_b4
[gzserver-2] [INFO] [1726750168.039244774] [gazebo_ros2_control]: State:
[gzserver-2] [INFO] [1726750168.039493774] [gazebo_ros2_control]: velocity
[gzserver-2] [INFO] [1726750168.039933974] [gazebo_ros2_control]: Command:
[gzserver-2] [INFO] [1726750168.040179774] [gazebo_ros2_control]: velocity
[gzserver-2] [INFO] [1726750168.040526874] [resource_manager]: Initialize hardware 'GazeboSystem'
[gzserver-2] [INFO] [1726750168.041151274] [resource_manager]: Successful initialization of hardware 'GazeboSystem'
[gzserver-2] [INFO] [1726750168.042096974] [resource_manager]: 'configure' hardware 'GazeboSystem'
[gzserver-2] [INFO] [1726750168.042257675] [resource_manager]: Successful 'configure' of hardware 'GazeboSystem'
[gzserver-2] [INFO] [1726750168.042413775] [resource_manager]: 'activate' hardware 'GazeboSystem'
[gzserver-2] [INFO] [1726750168.042566575] [resource_manager]: Successful 'activate' of hardware 'GazeboSystem'
[gzserver-2] [INFO] [1726750168.043140975] [gazebo_ros2_control]: Loading controller_manager
[gzserver-2] [WARN] [1726750168.233546918] [gazebo_ros2_control]: Desired controller update period (0.02 s) is slower than the gazebo simulation period (0.001 s).
[gzserver-2] [INFO] [1726750168.236298719] [gazebo_ros2_control]: Loaded gazebo_ros2_control.
[gzserver-2] [INFO] [1726750168.314883936] [controller_manager]: Loading controller 'joint_state_broadcaster'
[spawner-7] [INFO] [1726750168.461951169] [spawner_joint_state_broadcaster]: Loaded joint_state_broadcaster
[gzserver-2] [INFO] [1726750168.471040171] [controller_manager]: Configuring controller 'joint_state_broadcaster'
[gzserver-2] [INFO] [1726750168.471481972] [joint_state_broadcaster]: 'joints' or 'interfaces' parameter is empty. All available state interfaces will be published
[spawner-7] [INFO] [1726750168.587148598] [spawner_joint_state_broadcaster]: Configured and activated joint_state_broadcaster
[INFO] [spawner-7]: process has finished cleanly [pid 4321]
[INFO] [spawner-8]: process started with pid [4358]
[gzclient-3] context mismatch in svga_surface_destroy
[gzserver-2] [INFO] [1726750173.484798102] [controller_manager]: Loading controller 'velocity_controller'
[spawner-8] [INFO] [1726750173.815989176] [spawner_velocity_controller]: Loaded velocity_controller
[gzserver-2] [INFO] [1726750173.820977778] [controller_manager]: Configuring controller 'velocity_controller'
[gzserver-2] [INFO] [1726750173.830970380] [velocity_controller]: configure successful
[gzserver-2] [INFO] [1726750173.869233289] [velocity_controller]: activate successful
[spawner-8] [INFO] [1726750173.902301196] [spawner_velocity_controller]: Configured and activated velocity_controller
[INFO] [spawner-8]: process has finished cleanly [pid 4358]
Command what i use to turn it on:
ros2 launch my_bot launch_sim.launch.py
remapping
ros2 run teleop_twist_keyboard teleop_twist_keyboard --ros-args -r /cmd_vel:=/new_cmd_vel
i thought i have to turn the velocity controller by myself so the rotors start to move:
ros2 topic pub /velocity_controller/commands std_msgs/msg/Float64MultiArray “data: [50.5, 50.5, 50.5, 50.5]”
