GSoC 2020: Sensor Data Visualization
Organization: Open Source Robotics Foundation
Mentors: Ian Chen (@iche033), Alejandro Hernández Cordero (@ahcorde)
Student: Mihir Kulkarni (mihirk284@gmail.com)
Link to GSoC project: Google Summer of Code
Hello everyone,
This summer, I was selected to work on Sensor Data Visualization for the ignition-rendering library as a part of the Google Summer of Code program. This project is a part of a larger Ignition simulation framework, aiming to provide a new simulation platform for roboticists. This new simulation framework contains improvements and a redesign of the backbone of the simulation framework that exists in Gazebo. It supports distributed simulation, dynamic asset loading, and tunable performance. It also provides cross-platform support on Linux, macOS, and Windows, making simulation more accessible.
During the GSoC program, I worked directly on the ignition-rendering library to add sensor data visualization under the guidance of @iche033 and @ahcorde. I am grateful to Open Robotics for providing me with this opportunity. This summer has been a very enriching experience.
About the project
The project Sensor Data Visualization involves adding a new type of sensor visual to the ign-rendering library. This visual is used to render data collected from a simulated lidar sensor. It extends the capabilities of the LaserVisual present in Gazebo and adds new features to it. Implementation of the visual is present in both Ogre1 and Ogre2.
A new feature is added to the visual where the user can select whether they want to see only the rays hitting a particular obstacle. This means that the user can visually see the relevant information of the environment, as perceived by the robot, and avoid the clutter caused by visualization of the lidar data that is of no use to the robot. This has been done as it is difficult for the user to make sense of the data when the sensor rays are displayed too close to each other.
Apart from the original Triangle-Strips, new visual types are added that include Ray-Lines and Points. These have been added with the intention that the user will choose the visual that they want to see based on their application. The addition of Points adds the ability to visualize the points inside the simulation as well. Ray-Lines and Points are relatively faster to render and update than the Triangle-Strips visual type.
Additionally, a new material has been created in the form of a flat-square facing the user. This has been implemented in Ogre1, and the Ogre2 implementation is underway. This material is used to represent points. The user can set the independent colors for each point using the API. It is identical to the flat-square visual type of the PointCloud visual in RViz.
The developed visual was integrated with ign-gazebo as a loadable GUI plugin. The user can select the sensor message to display from and set the visual properties through the GUI. The following image shows a brief guide on the plugin:-
Demos
The implementation and the use of the Lidar Visual are demonstrated in the following GIFs.
The visual type can be changed between Triangle Strips, Rays, and Points, as demonstrated below. This application helps to visualize the points as seen by the sensor in the simulation.
gazebosim_blog1
The following GIF demonstrates the change of topics for visualizing the data. Once the topic is changed, the frame of the visual is also changed, and the origin of the visual is set similar to the sensor origin.
gazebosim_blog2
The behavior of the lidar visual is shown below when it is mounted on a mobile base. The deselection of the “Show Non Hitting Rays” checkbox removes the visual of the data from the lidar that does not detect any obstacle. As a result, it makes it easier for the user to see the obstacles being detected by the sensor in its field of view without the additional clutter.
gazebosim_blog3
Conclusion and Future plans
During the project, I was able to satisfy most of the goals. However, stretch goals like the addition of PointCloud to the rendering library is remaining.
I would really appreciate the community’s feedback to improve the features, address bugs, or implement new features that would make it easy for the users to use the plugins or the library.
I plan to continue contributing to ROS packages and Ignition libraries. I thank my mentors, @iche033 and @ahcorde for their constant support and guidance. GSoC’2020 has been a great experience, and I look forward to working with my mentors and Open Robotics in future projects.
About Me
I am an incoming Ph.D. student in the Computer Science program at the University Of Nevada, Reno. I graduated from Birla Institute of Technology and Science (BITS) Pilani, India, in 2020, with a bachelor’s degree in Mechanical Engineering.
I completed my Bachelor’s Thesis at the Autonomous Robots Lab, University of Nevada, Reno, where I worked on the motion planning for a reconfigurable aerial robotic system. My results were implemented using ROS and Gazebo and have now been published in a major conference. Through the lab, I am also a part of Team CERBERUS, participating in the DARPA Subterranean Challenge, focusing on autonomous search and rescue missions in constrained underground environments.
I have been involved in robotics-related projects for over three years, as a part of student clubs at my university. I have learned a lot during this time, and ROS and Gazebo have played a significant role during the journey. I hope to keep contributing to this wonderful community of innovators.
Thanks,
Mihir Kulkarni
