I have a pipe.obj
and pipe.stl
which can be opened in any CAD software(for eg. freecad). But when I try to open that in Gazebo Garden, the pipe.obj
shows up as a solid cylinder instead of a hollow one where as the pipe.stl
is not seen in the simulation itself although it shows up in the entity tree.
The CAD files is available here
My sdf is
<?xml version="1.0" ?>
<sdf version="1.9">
<world name="map">
<physics name="1ms" type="ignore">
<max_step_size>0.001</max_step_size>
<real_time_factor>1.0</real_time_factor>
</physics>
<plugin filename="gz-sim-physics-system"
name="gz::sim::systems::Physics">
<plugin filename="gz-sim-sensors-system"
name="gz::sim::systems::Sensors">
<render_engine>ogre2</render_engine>
<plugin filename="gz-sim-user-commands-system"
name="gz::sim::systems::UserCommands">
<plugin filename="gz-sim-scene-broadcaster-system"
name="gz::sim::systems::SceneBroadcaster">
<plugin filename="gz-sim-imu-system"
name="gz::sim::systems::Imu">
<!-- Moving Forward-->
<plugin filename="gz-sim-triggered-publisher-system"
name="gz::sim::systems::TriggeredPublisher">
<input type="gz.msgs.Int32" topic="/keyboard/keypress">
<match field="data">16777235</match>
</input>
<output type="gz.msgs.Twist" topic="/cmd_vel">
linear: {x: 0.2}, angular: {z: 0.0}
</output>
<!-- Moving Backward-->
<match field="data">16777237</match>
</input>
linear: {x: -0.2}, angular: {z: 0.0}
</output>
<!-- Moving Right-->
<match field="data">16777236</match>
</input>
linear: {x: 0.2}, angular: {z: -0.2}
</output>
<!-- Moving Left-->
<match field="data">16777234</match>
</input>
linear: {x: 0.2}, angular: {z: 0.2}
</output>
<!-- Stop Moving -->
<match field="data">48</match> <!-- 0 -->
</input>
linear: {y: -0.5}, angular: {z: 0.0}
</output>
<scene>
<ambient>1.0 1.0 1.0</ambient>
<background>0.8 0.8 0.8</background>
<sky></sky>
</scene>
<light type="directional" name="sun">
<cast_shadows>true</cast_shadows>
<pose>0 0 10 0 0 0</pose>
<diffuse>0.8 0.8 0.8 1</diffuse>
<specular>0.8 0.8 0.8 1</specular>
<attenuation>
<range>1000</range>
<constant>0.9</constant>
<linear>0.01</linear>
<quadratic>0.001</quadratic>
</attenuation>
<direction>-0.5 0.1 -0.9</direction>
</light>
<spherical_coordinates>
<latitude_deg>-35.3632621</latitude_deg>
<longitude_deg>149.1652374</longitude_deg>
<elevation>10.0</elevation>
<heading_deg>0</heading_deg>
<surface_model>EARTH_WGS84</surface_model>
</spherical_coordinates>
<model name="floor">
<plane>
<normal>0 0 1</normal>
<size>100 100</size>
</plane>
<surface>
<friction>
<ode>
<mu>100</mu>
<mu2>50</mu2>
</ode>
</friction>
</surface>
<cast_shadows>false</cast_shadows>
<plane>
</plane>
<diffuse>0.8 0.3 0.3 1</diffuse>
<model name="pipe">
<pose>0 50 -20 0 0 1.57</pose>
<mesh>
<uri>model://pipe/pipe.stl</uri>
<scale> 1 1 1 </scale>
</mesh>
<ambient>0.8 0.7 0.5 1</ambient>
<diffuse>0.6 0.3 0.5 1</diffuse>
<specular>0.2 0.7 0.8 1</specular>
<emissive>0 0 0 1</emissive>
<mesh>
</mesh>
</world>
Any thoughts please?
Thanks
