Highlights
Fortress
/Citadel
: Teleop widget now also supports vertical movement -
Fortress
/Citadel
: Plugin menu usable with keyboard: open with/
hotkey and navigate with arrow keys -
Fortress
/Citadel
: GUI snackbar element for standardized notifications -
Fortress
/Citadel
: Severalmath classes:
Polynomial3
,Region3
,PiecewiseScalarField3
,AdditivelySeparableScalarField3
,Matrix6
Fortress
: Support for kinematic loops withAttachFixedJoint
method in physics. -
Fortress
/Citadel
: Generic vector, pose and color widgets that make it easier to create custom GUI plugins with a consistent look and feel
Releases
These are the minor and patch releases that came out since the previous post.
Gazebo GUI 6.5.0 (Fortress)
Changelog
Teleop
: Refactor and support vertical - Change
IGN_DESIGNATION
toGZ_DESIGNATION
- Ignition → Gazebo
- Allow Dialogs to have a MainWindow independent config
- Add common widget for Vector3
- Add common widget for Pose
- Add common widget for Color
- Example running a dialog before the main window
- Test fixes and improvements
- Bash completion for flags
- Shortcut to search and auto highlight search bar
- Search menu keyboard control
- User camera FOV control in SDF files
- Add config relative path environment variable
- Add repo specific issue templates
- Sort plugin list in alphabetical order (including when filtering)
- Set
cameraPassCountPerGpuFlush
to 6 - Avoid nullptr access in MinimalScene
- Fix some Qt warnings
- Use
gz-rendering
’sscreenToScene
functions - Added Snackbar qtquick object
- Fix menu scrolling when a new plugin is added
TransportSceneManager
: Prevent freeze when inserted from menu - Populate plugins that were empty
- Prevent
MinimalScene
if another scene is already loaded
- Improve
KeyPublisher
’s usability - Removed unused code in
MinimalScene
plugin
Contributors
Addisu Z. Taddese
Alejandro Hernández Cordero
AzulRadio
Ian Chen
Jenn Nguyen
Jorge Perez
Louise Poubel
Mabel Zhang
Mohamad
Nate Koenig
Steve Peters
Gazebo GUI 3.10.0 and 3.11.0 (Citadel)
Changelog
- Dialog read attribute fixes
- Fixed topic echo test
- Teleop: Refactor and support vertical
- Change
IGN_DESIGNATION
toGZ_DESIGNATION
- Ignition → Gazebo
- Add common widget for vector3
- Add common widget for pose
- Common widget GzColor
- Fix ign_TEST
- Make display tests more robust
- Disable failing test on Citadel
- Added array to snackbar qml
- Improve KeyPublisher’s usability
- Backport GridConfig improvements to Citadel’s Grid3D
Contributors
AzulRadio
Jenn Nguyen
Jorge Perez
Louise Poubel
Mabel Zhang
Mohamad
Nate Koenig
Gazebo Physics 5.2.0 (Fortress)
Changelog
- DART: support non-tree kinematics in AttachFixedJoint
- Use
SuppressWarning
fromgz-utils
- Make
CONFIG
a CMake pass-through option for DART - Remove explicitly-defined copy constructor/operator
- Fix
ExpectData
compiler warnings - Fix copying of ExpectData objects
- Add Ubuntu Jammy CI
- Fix Apache license version
- Add
project()
to examples
Contributors
Addisu Z. Taddese
Ashton Larkin
Ian Chen
Jochen Sprickerhof
Louise Poubel
Mabel Zhang
Michael Carroll
Steve Peters
Gazebo Msgs 8.6.0 (Fortress)
Changelog
- Increase
Utility
test coverage - Change
IGN_DESIGNATION
toGZ_DESIGNATION
- Add entity wrench message
- Ignition → Gazebo
- Add
ACTOR
andWORLD
types to entity
Contributors
Jenn Nguyen
Louise Poubel
Nate Koenig
Gazebo Msgs 5.10.0 (Citadel)
Changelog
- Ignition → Gazebo
- Add
ACTOR
andWORLD
types to entity - Bash completion for flags
- Remove dead files
- Fix typo REGRESION/REGRESSION
- Generator: Add missing std namespace to string arguments
Contributors
Jenn Nguyen
Louise Poubel
Mabel Zhang
Silvio Traversaro
Gazebo CMake 2.13.0 & 2.14.0 (Citadel / Fortress)
Changelog
- Add code coverage ignore file
- Backport
GZ_DESIGNATION
tick-tock - Upload docs to an s3 bucket based only on the major version
- Exclude proto generated cpp in coverage test
- Add LTCG flag on Windows builds
- Update codeowners
- Update documentation to gazebosim.org
- Improving
CONFIG
test
Contributors
Ashton Larkin
AzulRadio
Harsh Mahesheka
Jenn Nguyen
Jose Luis Rivero
Nate Koenig
Steve Peters
Gazebo Math 6.12.0 (Citadel / Fortress)
Changelog
- Added Helper function
isTimeString
to Python - Ignition → Gazebo
- Added
*.pyc
to.gitignore
- Alphabetize examples
- Add
class - Add
class - Add
Polynomial3
class - Add
Region3
class - Add
Interval
class - Add
Matrix6
class - Backport newest
appendToStream
functions - Use pytest to generate junit xml files for python tests
- Add Aditya as codeowner
Contributors
Aditya Pande
Jenn Nguyen
Louise Poubel
Michel Hidalgo
Nate Koenig
Gazebo Transport 8.3.0 (Citadel)
Changelog
- Ignition → Gazebo
- Focal CI: static checkers, doxygen linters, compiler warnings
- Remove no username error messages
- Documented the default value of
GZ_PARTITION
- Remove static on
registrationCb
andunregistrationCb
Contributors
Alexander Graber-Tilton
Hill Ma
Jenn Nguyen
Louise Poubel
Mabel Zhang
Martin Pecka
Michael Carroll
Nate Koenig
Steve Peters
