Is there planar move plugin in Gazebo Ignition
I’m using gazebo ignition fortress with ros2 humble
Previously in gazebo classic there is a planar move plugin Gazebo : Tutorial : Gazebo plugins in ROS
Is this available in gazebo ignition fortress? If so, is there any example on how to implement it into my urdf/xacro file
Hi @leets0429,
Did you find an answer? I am also interested
No, I ended up just using the differential drive plugin for now
