Ignition Dome tutorial party 🄳
Hi community,
Ignition’s 4th collection, Dome, is planned for release on September 30th. Before each major release, the team goes over all the tutorials using pre-releases to check that everything is working as it should and make final tweaks. This time, we’d like to invite the community to join the party! :partying_face: This should be a great opportunity for Gazebo-classic users to get their feet wet with its next generation.
We’ll be partying from September 24th until September 29th.
Install pre-releases
All Dome libraries have been pre-released. The following installation methods are available:
Tutorials
We’ll be using this spreadsheet to coordinate:
Workflow:
  1. Pick an installation method:
    • Bionic binaries
    • Bionic source
    • Focal binaries
    • Focal source
    • Mojave binaries
    • Mojave source
    • Catalina binaries
    • Catalina source
  2. Pick a tutorial from the list and write your name as the reviewer - give preference to tutorials which haven’t been tested on any platform yet
  3. Follow the instructions and check everything works as expected - be as thorough as possible
  4. If something is wrong:
    1. If you know how to change the tutorial or code to make it work, open a pull request and add a link to it on the spreadsheet
    2. If you don’t know what’s wrong, raise the issue here ASAP
  5. If nothing is wrong, put an ā€œOk!ā€ on the status and go back to #2 (or #1)
Happy igniting!
:fire: The Ignition Dev Team :fire:
