How to use NavSat plugin
I’m trying to use the Navsat plugin but I can’t get it working. I’m using ros-humble
I’ve been following the link below, but I am unable to see any navsat topic in gazebo
https://answers.gazebosim.org//question/28643/gps-sensor-plugin-in-ignition/
In my robot urdf, I have the following code
    <link name="chassis">
      <plugin filename="ignition-gazebo-navsat-system" name="ignition::gazebo::systems::NavSat"/>
      <gazebo>
        <sensor name="navsat_sensor" type="navsat">
          <update_rate>1</update_rate>
          <topic>navsat</topic>
On my world sdf, I also included
    <world name="field">
      <spherical_coordinates>
        <surface_model>EARTH_WGS84</surface_model>
        <world_frame_orientation>ENU</world_frame_orientation>
        <latitude_deg>-22.986687</latitude_deg>
        <longitude_deg>-43.202501</longitude_deg>
        <elevation>0</elevation>
        <heading_deg>0</heading_deg>
      </spherical_coordinates>
    </world>
This type of question seems better suited for robotics.stackexchange.com .
