I’m runnning a neuroevolution algorithm using Gazebo Fortress and ROS 2 Humble, with the Turtlebot 4 robot. In my project I need to run ~10k short runs (1 minute each) and for every run I need to change the starting position of the robot and the objects (yellow cylinders), as shown in the video below.
To do this I have a bash file
that calls the gazebo service to set the new position of the objects, the command is the following:
ign service -s /world/arena/set_pose --reqtype ignition.msgs.Pose --reptype ignition.msgs.Boolean --req \"name: 'object$obj_id' position: { x: $(eval echo \$OBJECT${obj_id}_X), y: $(eval echo \$OBJECT${obj_id}_Y), z: $OBJECT_Z} orientation: { x: 0.0, y: 0.0, z: 0.0, w: 1.0 }\" --timeout 5000
And this command is embedded in the following function in a bash
script:
generate_random_position_object() {
local obj_id=$1
while true; do
local x=$(awk -v min=$X_MIN_OBJ -v max=$X_MAX_OBJ -v seed=$RANDOM 'BEGIN{srand(seed); print min+rand()*(max-min)}')
local y=$(awk -v min=$Y_MIN_OBJ -v max=$Y_MAX_OBJ -v seed=$RANDOM 'BEGIN{srand(seed); print min+rand()*(max-min)}')
# Check if the generated position is too close to the TurtleBot4
local distance_to_turtlebot
distance_to_turtlebot=$(awk -v x1=$TURTLEBOT_X -v y1=$TURTLEBOT_Y -v x2=$x -v y2=$y 'BEGIN{print sqrt((x2-x1)^2 + (y2-y1)^2)}')
if (( $(echo "$distance_to_turtlebot <= 0.5" | bc -l) )); then
continue
fi
# Check if the generated position is too close to any other objects
local valid=true
for existing_obj in OBJECT1 OBJECT2 OBJECT3 OBJECT4 OBJECT5 OBJECT6 OBJECT7; do
local obj_x=${existing_obj}_X
local obj_y=${existing_obj}_Y
local distance_to_obj
distance_to_obj=$(awk -v x1=${!obj_x} -v y1=${!obj_y} -v x2=$x -v y2=$y 'BEGIN{print sqrt((x2-x1)^2 + (y2-y1)^2)}')
if (( $(echo "$distance_to_obj <= 0.2" | bc -l) )); then
valid=false
break
fi
done
if [ "$valid" = true ]; then
eval "OBJECT${obj_id}_X=$x"
eval "OBJECT${obj_id}_Y=$y"
break
fi
done
repeat_ign_command "ign service -s /world/arena/set_pose --reqtype ignition.msgs.Pose --reptype ignition.msgs.Boolean --req \"name: 'object$obj_id' position: { x: $(eval echo \$OBJECT${obj_id}_X), y: $(eval echo \$OBJECT${obj_id}_Y), z: $OBJECT_Z} orientation: { x: 0.0, y: 0.0, z: 0.0, w: 1.0 }\" --timeout 5000"
echo "respawned object${obj_id}"
eval echo "\$OBJECT${obj_id}_X"
eval echo "\$OBJECT${obj_id}_Y"
To change the position of the turtlebot4 I use the following command: ign service -s /world/arena/set_pose --reqtype ignition.msgs.Pose --reptype ignition.msgs.Boolean --req \"name: 'turtlebot4' position: { x: $TURTLEBOT_X, y: $TURTLEBOT_Y, z: $TURTLEBOT_Z } orientation: { x: $TURTLEBOT_QX, y: $TURTLEBOT_QY, z: $TURTLEBOT_QZ, w: $TURTLEBOT_QW}\" --timeout 2000
What I have noticed is that after some runs I need to repeat these commands multiple times to move the robot and the objects since I keep receiving the output Service call timed out
This is the entire bash
script that I use to handle the single simulation run (sorry if some comments are not in english):
#!/bin/bash
source /opt/ros/humble/setup.bash
source /workspace/turtlebot4_minimize_surprise/install/setup.bash
SIMULATION_TIME=60
# set spawn limit turtlebot4
X_MIN_TB=-1.8
X_MAX_TB=1.8
Y_MIN_TB=-0.2
Y_MAX_TB=3.5
# set spawn limit objects
X_MIN_OBJ=-1.8
X_MAX_OBJ=1.8
Y_MIN_OBJ=2.6
Y_MAX_OBJ=3.5
# variables to store turtlebot4 starting position and orientation
TURTLEBOT_X=0
TURTLEBOT_Y=0
TURTLEBOT_Z=0
TURTLEBOT_QX=0
TURTLEBOT_QY=0
TURTLEBOT_QZ=0
TURTLEBOT_QW=1
# variables to store objects position
OBJECT1_X=0
OBJECT1_Y=0
OBJECT2_X=0
OBJECT2_Y=0
OBJECT3_X=0
OBJECT3_Y=0
OBJECT4_X=0
OBJECT4_Y=0
OBJECT5_X=0
OBJECT5_Y=0
OBJECT6_X=0
OBJECT6_Y=0
OBJECT7_X=0
OBJECT7_Y=0
OBJECT_Z=0.2
# array to store object positions and orientations
declare -A OBJECTS
# function to spawn random position turtlebot
generate_random_position_turtlebot() {
local x_min=$1
local x_max=$2
local y_min=$3
local y_max=$4
# generate random coordinate within limits
local x=$(awk -v min=$x_min -v max=$x_max -v seed=$RANDOM 'BEGIN{srand(seed); print min+rand()*(max-min)}')
local y=$(awk -v min=$y_min -v max=$y_max -v seed=$RANDOM 'BEGIN{srand(seed); print min+rand()*(max-min)}')
# generate z coordiante based on y values
local z
#if (( $(echo "$y > 2.6" | bc -l) )); then # source limit
# z=0.11
#elif (( $(echo "$y >= 1.5 && $y <= 2.6" | bc -l) )); then # slope limits
# z=0.09
#else # cache and nest limit
# z=0.04
#fi
z=0.15
# Assegna i valori generati alle variabili globali
TURTLEBOT_X=$x
TURTLEBOT_Y=$y
TURTLEBOT_Z=$z
# function to spawn a random orientation (z-axis) turtlebot
generate_random_orientation_turtlebot() {
# Generate a random yaw (rotation around z-axis) between 0 and 2*pi
local yaw=$(awk 'BEGIN{srand(); print rand() * 2 * 3.14159265359}')
# Convert the yaw to a quaternion (assuming no pitch or roll)
TURTLEBOT_QX=0
TURTLEBOT_QY=0
TURTLEBOT_QZ=$(awk -v yaw=$yaw 'BEGIN{print sin(yaw / 2)}')
TURTLEBOT_QW=$(awk -v yaw=$yaw 'BEGIN{print cos(yaw / 2)}')
repeat_ign_command() { # repeat the call to an ignition command until is executed correctly
local command="$1" # Primo argomento: comando Ignition da eseguire
local response="" # Variabile per memorizzare la risposta
echo "Debug: Il comando passato è -> $command" # Debug
# Loop infinito fino a quando non c'è un timeout
while true; do
# Esegue il comando e cattura l'output
echo "Eseguendo comando: $command"
response=$(eval "$command")
# Controlla se la risposta è "Service call timed out"
if [[ "$response" == "Service call timed out" ]]; then
echo "Timeout del servizio. Ritento..."
sleep 1 # Ritardo prima di ritentare
continue
fi
# Se la risposta non è un timeout, esci dal loop
break
done
echo "Comando completato con successo o risposta valida ricevuta!"
local obj_id=$1
while true; do
continue
fi
local valid=true
valid=false
break
fi
done
break
fi
done
simulation_id=$1
genome_id=$2
echo -e "\n---------------------------\nGenome ID: $genome_id, Simulation ID: $simulation_id\n---------------------------"
export ROS_DOMAIN_ID=$simulation_id && export IGN_PARTITION=$simulation_id
fastdds shm clean # https://github.com/eProsima/Fast-DDS/issues/2003#issuecomment-1160245640
while true; do
echo "Update genome_id"
timeout 10 ros2 param set /ann_controller genome_id $genome_id # set the genome_id
result=$?
echo "Exit code: $result"
if [ $result -eq 0 ]; then break; fi
sleep 2
done
echo "set new genome"
sleep 5
while true; do
timeout 10 ros2 param set /ann_controller update_genome_id True
result=$?
sleep 2
done
echo "enabled genome"
# generate random position turtlebot4
generate_random_position_turtlebot $X_MIN_TB $X_MAX_TB $Y_MIN_TB $Y_MAX_TB
sleep 2
# generate random orientation turtlebot4
sleep 2
# # reset turtlebot4 position
echo "Respawning turtlebot4"
repeat_ign_command "ign service -s /world/arena/set_pose --reqtype ignition.msgs.Pose --reptype ignition.msgs.Boolean --req \"name: 'turtlebot4' position: { x: $TURTLEBOT_X, y: $TURTLEBOT_Y, z: $TURTLEBOT_Z } orientation: { x: $TURTLEBOT_QX, y: $TURTLEBOT_QY, z: $TURTLEBOT_QZ, w: $TURTLEBOT_QW}\" --timeout 2000"
echo "Turtlebot4 respawned"
# Generate and set positions for objects individually
echo "Respawning object1"
generate_random_position_object "1"
#ign service -s /world/arena/set_pose --reqtype ignition.msgs.Pose --reptype ignition.msgs.Boolean --req "name: 'object1' position: { x: $OBJECT1_X, y: $OBJECT1_Y, z: $OBJECT_Z} orientation: { x: 0.0, y: 0.0, z: 0.0, w: 1.0 }" --timeout 2000
#sleep 2
echo "Respawning object2"
generate_random_position_object "2"
#ign service -s /world/arena/set_pose --reqtype ignition.msgs.Pose --reptype ignition.msgs.Boolean --req "name: 'object2' position: { x: $OBJECT2_X, y: $OBJECT2_Y, z: $OBJECT_Z} orientation: { x: 0.0, y: 0.0, z: 0.0, w: 1.0 }" --timeout 2000
#sleep 2
echo "Respawning object3"
generate_random_position_object "3"
#ign service -s /world/arena/set_pose --reqtype ignition.msgs.Pose --reptype ignition.msgs.Boolean --req "name: 'object3' position: { x: $OBJECT3_X, y: $OBJECT3_Y, z: $OBJECT_Z} orientation: { x: 0.0, y: 0.0, z: 0.0, w: 1.0 }" --timeout 2000
#sleep 2
echo "Respawning object4"
generate_random_position_object "4"
#ign service -s /world/arena/set_pose --reqtype ignition.msgs.Pose --reptype ignition.msgs.Boolean --req "name: 'object4' position: { x: $OBJECT4_X, y: $OBJECT4_Y, z: $OBJECT_Z} orientation: { x: 0.0, y: 0.0, z: 0.0, w: 1.0 }" --timeout 2000
#sleep 2
echo "Respawning object5"
generate_random_position_object "5"
#ign service -s /world/arena/set_pose --reqtype ignition.msgs.Pose --reptype ignition.msgs.Boolean --req "name: 'object5' position: { x: $OBJECT5_X, y: $OBJECT5_Y, z: $OBJECT_Z} orientation: { x: 0.0, y: 0.0, z: 0.0, w: 1.0 }" --timeout 2000
#sleep 2
echo "Respawning object6"
generate_random_position_object "6"
#ign service -s /world/arena/set_pose --reqtype ignition.msgs.Pose --reptype ignition.msgs.Boolean --req "name: 'object6' position: { x: $OBJECT6_X, y: $OBJECT6_Y, z: $OBJECT_Z} orientation: { x: 0.0, y: 0.0, z: 0.0, w: 1.0 }" --timeout 2000
#sleep 2
echo "Respawning object7"
generate_random_position_object "7"
#ign service -s /world/arena/set_pose --reqtype ignition.msgs.Pose --reptype ignition.msgs.Boolean --req "name: 'object7' position: { x: $OBJECT7_X, y: $OBJECT7_Y, z: $OBJECT_Z} orientation: { x: 0.0, y: 0.0, z: 0.0, w: 1.0 }" --timeout 2000
#sleep 2
# start simulation
echo -e "start simulation\n"
repeat_ign_command "ign service -s /world/arena/control --reqtype ignition.msgs.WorldControl --reptype ignition.msgs.Boolean --timeout 5000 --req 'pause: false'"
echo "simulation started"
#sleep $SIMULATION_TIME & # simulation time
# record the rosbag
ros2 bag record -o /workspace/simulation_log/$genome_id/bag \
/model/turtlebot4/pose \
/cmd_vel \
/cliff_sensor_front_left \
/cliff_sensor_front_right \
/cliff_sensor_side_left \
/cliff_sensor_side_right \
/light_sensor_frontL \
/light_sensor_frontR \
/light_sensor_back \
/hazard_detection \
/scan \
/model/object1/pose \
/model/object2/pose \
/model/object3/pose \
/model/object4/pose \
/model/object5/pose \
/model/object6/pose \
/model/object7/pose &
BAG_PID=$!
kill $BAG_PID
sleep 2
echo "save score"
#ros2 topic echo /fitness_topic --once > log2/$genome_id/score.txt # store the score
# path to run the simulation with the HPC workspace
ros2 topic echo /fitness_topic --once > /workspace/simulation_log/$genome_id/score.txt
sleep 2
echo "stop simulation"
repeat_ign_command "ign service -s /world/arena/control --reqtype ignition.msgs.WorldControl --reptype ignition.msgs.Boolean --timeout 5000 --req 'pause: true'" # stop simulation
sleep 2
echo "simulation stopped"
What can be the cause of this problem? I guess it’s something related to Gazebo but I’m struggling to figure the source of the problem since the simulation works even after almost 2k runs (with the same Real-Time factor as the beginning).
