I was able to launch the gazebo using ros2 launch and also reading the sensor data , or I mean printing them as a log in the console
My question is :
I have built and launched the gazebo from the source code, not binaries, so I am searching for the source code to calculate the IMU sensor values, such as the orientation and linear /angular velocities.
I found the imu.cc, but I guess this was used to read the SDF configuration, and I need your help to find the source code that calculated these readings please.
The code that performs the calculations is defined in the gz::sensors::ImuSensor in the gz-sensors project:
The file Imu.cc defines a system that manages instances of ImuSensor. For every SDFormat Specification sensor of type=imu in your SDF files, it creates one entity of ImuSensor.
