Cannot open local sdf file in ignition gazebo
I am trying out the ignition gazebo citadel, and I am a bit confused on how this works compared to the classical gazebo.
I have a local model.sdf that I want to open in ignition gazebo. However, the application exists without any obvious errors. The output on the console is as the following.
ign gazebo ./model.sdf -v 5
[Msg] Ignition Gazebo Server v2.15.0
[Msg] Ignition Gazebo GUI    v2.15.0
[Msg] Loading SDF world file[/home/jaeyoung/src/Firmware/Tools/sitl_gazebo/models/uneven_ground/./model.sdf].
[Dbg] [Application.cc:87] Initializing application.
[GUI] [Dbg] [Application.cc:407] Create main window
[Dbg] [ign.cc:150] Shutting down ign-gazebo-server
[GUI] [Dbg] [SignalHandler.cc:141] Received signal[2].
[GUI] [Dbg] [Application.cc:130] Terminating application.
Version of ignition gazebo is:
$ ign gazebo --version
Ignition Gazebo, version 2.15.0
Copyright (C) 2018 Open Source Robotics Foundation.
Released under the Apache 2.0 License.
Hi @Jaeyoung-Lim,
On Ignition, unlike Gazebo-classic, you need to include all world plugins that will be loaded, like Physics and UserCommands. Have you checked that your world has a few plugins? A good list to start with would be this. We’re currently working on a new feature so users don’t need to specify all plugins all the time.
If that’s not the problem, would you mind sharing a minimal version of your file that reproduces the problem?
Also, this kind of question is better suited for https://answers.gazebosim.org, would you mind if we continued the conversation there?
Cheers
@chapulina Thanks, I have posted the question here: https://answers.gazebosim.org/question/24586/cannot-open-local-sdf-file-in-ignition-gazebo/
