Problem loading gazebo
While loading gazebo I’m getting the following error
gzserver: error while loading shared libraries: libdart-collision-bullet.so.6.12: cannot open shared object file: No such file or directory
however when I try to install libdart-collision-bullet-dev, it says
libdart-collision-bullet-dev is already the newest version (6.9.2-2build4).
Can anyone help me out with what’s wrong?
just passing by
it seems that the gazebo you have installed has been built with a newer libdart-collision-bullet
I would recommend trying to reinstall gazebo and see if the error still shows up and doesn’t self - resolve
Thank you for the reply!
I tried reinstalling gazebo using the gazebo documentation
In the ### Build And Install Gazebo step
I ran the following command in /tmp/gazebo/build
cmake ../
it gave me the following error:
Could not find a package configuration file provided by "sdformat9"
  (requested version 9.8) with any of the following names:
    sdformat9Config.cmake
    sdformat9-config.cmake
I installed dependencies using the following link
but still end up with the same issue
Is there any other dependency I might be missing?
What linux distribution are you using?
You should try to avoid building from source if possible.
I am using Ubuntu 20.04
So for ubuntu 20, the version of gazebo to use is gazebo 9.
What is the output of sudo apt install gazebo9?
So I uninstalled gazebo using
sudo apt-get remove '.*gazebo.*' '.*sdformat.*' '.*ignition-math.*' '.*ignition-msgs.*' '.*ignition-transport.*'
installed the dependencies from the below link
and then tried
it gives the below error :
gazebo: error while loading shared libraries: libsdformat9.so.9: cannot open shared object file: No such file or directory
Just a note : I have previously faced this issue and installed the library manually, which asked for more dependencies, after finally resolving those dependencies I land with my original error i.e.
