Gazebo Harmonic/Jazzy plugins? /cmd_vel topic not being published diff-drive-system
I am a beginner, trying to get a differential drive robot to navigate around obstacles in Gazebo Harmonic. I have made a basic differential drive robot .urdf file which includes the following:
<plugin filename="gz-sim-diff-drive-system" name="gz::sim::systems::DiffDrive">
            <odom_publisher_frequency>50</odom_publisher_frequency>
            <left_joint>left_wheel_joint</left_joint>
            <right_joint>right_wheel_joint</right_joint>
            <wheel_separation>0.35</wheel_separation>
            <wheel_diameter>0.2</wheel_diameter>
            <max_wheel_torque>20</max_wheel_torque>
            <max_linear_acceleration>1.0</max_linear_acceleration>
            <topic>cmd_vel</topic>
            <publish_odom>true</publish_odom>
            <publish_odom_tf>true</publish_odom_tf>
            <publish_wheel_tf>true</publish_wheel_tf>
            <odom_topic>odom</odom_topic>
            <frame_id>odom</frame_id>
            <child_frame_id>base_link</child_frame_id>
I believe this plugin should be publishing a /cmd_vel topic that I can use to command the robot’s velocity from some other node, e.g. a Nav2 node. However, when I check ros2 topic list I don’t see a /cmd_vel topic published.
Some searching around led me to this post: ros2 - No /odom and /cmd_vel topics with diff_drive plugin - Robotics Stack Exchange
where the authors had a similar issue. However, their solution was to install
ros-humble-gazebo-plugins
I am on Ubuntuu 24.04, so am using Jazzy, and my system cannot find ros-jazzy-gazebo-plugins.
Does anyone have any further advice on how to debug?
I’m having the exact same issue.
Maybe this can help you
https://robotics.stackexchange.com/questions/110989/gazebo-plugin-not-creating-cmd-vel-and-odom-topics-in-ros-2-humble-with-gazebo-f
