Hi everyone,
I currently have a problem with angular rotation when using the gz::sim::systems::DiffDrive plugin.
The gz.msgs.Twist msg looks fine and I have tried different wheel friction values. However, it doesnt look like friction is the issue since linear motion is fine.
Here is the video
and the model.sdf file
<?xml version="1.0" encoding="utf-8"?>
<sdf version='1.9'>
<model name='scout_mini'>
<static>false</static>
<pose>0 0 0.182 0 0 0</pose>
<link name='base_link'>
<pose>0 0 0 0 -0 0</pose>
<mass>60</mass>
<ixx>2.28864</ixx>
<iyy>5.10398</iyy>
<izz>3.43147</izz>
<collision name='base_link_collision'>
<pose>0 0 0 1.57 -0 -1.57</pose>
<size>0.5 0.3 0.2</size>
<visual name='base_link_visual'>
<mesh>
<scale>1 1 1</scale>
<uri>meshes/scout_mini_base_link2.dae</uri>
</mesh>
<!-- IMU/MAG {-->
<sensor name='imu_sensor' type='imu'>
<always_on>true</always_on>
<update_rate>250</update_rate>
<gyroscopeNoiseDensity>0.00018665</gyroscopeNoiseDensity>
<gyroscopeRandomWalk>3.8785e-05</gyroscopeRandomWalk>
<gyroscopeBiasCorrelationTime>1000.0</gyroscopeBiasCorrelationTime>
<gyroscopeTurnOnBiasSigma>0.0087</gyroscopeTurnOnBiasSigma>
<accelerometerNoiseDensity>0.00186</accelerometerNoiseDensity>
<accelerometerRandomWalk>0.006</accelerometerRandomWalk>
<accelerometerBiasCorrelationTime>300.0</accelerometerBiasCorrelationTime>
<accelerometerTurnOnBiasSigma>0.196</accelerometerTurnOnBiasSigma>
<sensor name='magnetometer_sensor' type='magnetometer'>
<update_rate>100</update_rate>
<visualize>false</visualize>
<enable_metrics>false</enable_metrics>
<magnetometer>
<x>
<noise type="gaussian">
<mean>0.0</mean>
<stddev>0.1</stddev>
</noise>
</x>
<y>
<mean>0.0</mean>
</noise>
</y>
<z>
<mean>0.0</mean>
</noise>
</z>
</magnetometer>
<!--} END IMU/MAG -->
<joint name='front_left_wheel_joint' type='revolute'>
<pose relative_to='base_link'>0.231976 0.208252 -0.100998 -1.57 0 0</pose>
<parent>base_link</parent>
<child>front_left_wheel_link</child>
<axis>
<xyz>0 0 1</xyz>
<limit>
<lower>-1e+16</lower>
<upper>1e+16</upper>
</limit>
<dynamics>
</dynamics>
</axis>
<link name='front_left_wheel_link'>
<pose relative_to='front_left_wheel_joint'>0 0 0 0 -0 0</pose>
<mass>3</mass>
<ixx>0.7171</ixx>
<iyy>0.7171</iyy>
<izz>0.1361</izz>
<collision name='front_left_wheel_link_collision'>
<sphere>
<radius>0.0775</radius>
</sphere>
<max_contacts>1</max_contacts>
<surface>
<friction>
<ode>
<mu>0.5</mu>
<mu2>0.5</mu2>
<slip1>0.0016</slip1>
<slip2>0</slip2>
<fdir1>0 0 1</fdir1>
</ode>
</friction>
<contact>
<ode>
<min_depth>0.001</min_depth>
<max_vel>0.0</max_vel>
<kp>1.0e7</kp>
<kd>1.0</kd>
</ode>
</contact>
</surface>
<visual name='front_left_wheel_link_visual'>
<mesh>
<uri>meshes/wheel.dae</uri>
</mesh>
<joint name='front_right_wheel_joint' type='revolute'>
<pose relative_to='base_link'>0.231976 -0.208252 -0.099998 1.57 -0 0</pose>
<child>front_right_wheel_link</child>
<axis>
<xyz>0 0 -1</xyz>
<limit>
</limit>
<dynamics>
</dynamics>
</axis>
<link name='front_right_wheel_link'>
<pose relative_to='front_right_wheel_joint'>0 0 0 0 -0 0</pose>
<mass>3</mass>
<ixx>0.7171</ixx>
<iyy>0.7171</iyy>
<izz>0.1361</izz>
<collision name='front_right_wheel_link_collision'>
<sphere>
</sphere>
<surface>
<friction>
<ode>
<mu>0.5</mu>
<mu2>0.5</mu2>
<slip2>0</slip2>
</ode>
</friction>
<contact>
<ode>
<kp>1.0e7</kp>
<kd>1.0</kd>
</ode>
</contact>
</surface>
<visual name='front_right_wheel_link_visual'>
<mesh>
</mesh>
<joint name='rear_left_wheel_joint' type='revolute'>
<pose relative_to='base_link'>-0.231976 0.208252 -0.100998 -1.57 0 0</pose>
<child>rear_left_wheel_link</child>
<axis>
<xyz>0 0 1</xyz>
<limit>
</limit>
<dynamics>
</dynamics>
</axis>
<link name='rear_left_wheel_link'>
<pose relative_to='rear_left_wheel_joint'>0 0 0 0 -0 0</pose>
<mass>3</mass>
<ixx>0.7171</ixx>
<iyy>0.7171</iyy>
<izz>0.1361</izz>
<collision name='rear_left_wheel_link_collision'>
<sphere>
</sphere>
<surface>
<friction>
<ode>
<mu>0.5</mu>
<mu2>0.5</mu2>
<slip2>0</slip2>
</ode>
</friction>
<contact>
<ode>
<kp>1.0e7</kp>
<kd>1.0</kd>
</ode>
</contact>
</surface>
<visual name='rear_left_wheel_link_visual'>
<mesh>
</mesh>
<joint name='rear_right_wheel_joint' type='revolute'>
<pose relative_to='base_link'>-0.231976 -0.208252 -0.099998 1.57 -0 0</pose>
<child>rear_right_wheel_link</child>
<axis>
<xyz>0 0 -1</xyz>
<limit>
</limit>
<dynamics>
</dynamics>
</axis>
<link name='rear_right_wheel_link'>
<pose relative_to='rear_right_wheel_joint'>0 0 0 0 -0 0</pose>
<mass>3</mass>
<ixx>0.7171</ixx>
<iyy>0.7171</iyy>
<izz>0.1361</izz>
<collision name='rear_right_wheel_link_collision'>
<sphere>
</sphere>
<surface>
<friction>
<ode>
<mu>0.5</mu>
<mu2>0.5</mu2>
<slip2>0</slip2>
</ode>
</friction>
<contact>
<ode>
<kp>1.0e7</kp>
<kd>1.0</kd>
</ode>
</contact>
</surface>
<visual name='rear_right_wheel_link_visual'>
<mesh>
</mesh>
<static>0</static>
<!-- GPS {-->
<link name='gps1_link'>
<pose>0 0 0 0 0 0</pose>
<mass>0.01</mass>
<ixx>2.1733e-06</ixx>
<iyy>2.1733e-06</iyy>
<izz>1.8e-07</izz>
<visual name='visual'>
<cylinder>
<radius>0.01</radius>
<length>0.002</length>
</cylinder>
<script>
<name>Gazebo/Black</name>
</script>
<sensor name='gps' type='navsat'>
<update_rate>10</update_rate>
<gpsNoise>1</gpsNoise>
<gpsXYRandomWalk>2.0</gpsXYRandomWalk>
<joint name='gps1_joint' type='fixed'>
<child>gps1_link</child>
<!--} END GPS -->
<!-- RP Lidar {-->
<link name="2d_scanner_link">
<pose>0 0 0.089 0 0 0</pose>
<mass>0.01</mass>
<ixx>0.000166667</ixx>
<iyy>0.000166667</iyy>
<izz>0.000166667</izz>
<sensor name='rplidar' type='gpu_lidar'>
<update_rate>20</update_rate>
<lidar>
<scan>
<horizontal>
<samples>720</samples>
<resolution>1</resolution>
<min_angle>-3.1241390751</min_angle>
<max_angle>3.1241390751</max_angle>
</horizontal>
<vertical>
<samples>1</samples>
<min_angle>0.0</min_angle>
<max_angle>0.0</max_angle>
</vertical>
</scan>
<range>
<min>0.15</min>
<max>14</max>
<resolution>0.01</resolution>
</range>
</lidar>
<visual name='rplidar_visual'>
<mesh>
<uri>meshes/rplidar.dae</uri>
</mesh>
<joint name='2d_scanner_joint' type='fixed'>
<child>2d_scanner_link</child>
<!--} END RP Lidar -->
<!-- CAMERA {-->
<link name="camera_link">
<mass>0.01</mass>
<size>0.01 0.01 0.01</size>
<sensor name="ugv-camera" type="camera">
<width>1280</width>
<height>720</height>
<far>100</far>
<joint name='camera_joint' type='fixed'>
<child>camera_link</child>
<axis>
<xyz>1 0 0</xyz>
<limit>
<lower>0</lower>
<upper>0</upper>
<effort>0</effort>
<velocity>0</velocity>
</limit>
<dynamics>
</dynamics>
</axis>
<!--} END CAMERA -->
<!-- Plugins {-->
<!-- diff drive plugin :
1. drive the robot with cmd_vel (PX4 mode: throttle and steering from PX4
via gz_bridge masqueraded as cmd_vel from PX4 via gz_bridge)
2. publish odom /robot_name/odom -> /robot_name (PX4 mode: not used since
PX4 publishes odom)
filename="gz-sim-diff-drive-system"
name="gz::sim::systems::DiffDrive">
<left_joint>front_left_wheel_joint</left_joint>
<left_joint>rear_left_wheel_joint</left_joint>
<right_joint>front_right_wheel_joint</right_joint>
<right_joint>rear_right_wheel_joint</right_joint>
<wheel_separation>0.49</wheel_separation>
<wheel_radius>0.0775</wheel_radius>
<max_linear_acceleration>1</max_linear_acceleration>
<min_linear_acceleration>-1</min_linear_acceleration>
<max_angular_acceleration>2</max_angular_acceleration>
<min_angular_acceleration>-2</min_angular_acceleration>
<max_linear_velocity>0.5</max_linear_velocity>
<min_linear_velocity>-0.5</min_linear_velocity>
<max_angular_velocity>1</max_angular_velocity>
<min_angular_velocity>-1</min_angular_velocity>
<frame_id>scout_mini/odom</frame_id>
<child_frame_id>scout_mini/base_link</child_frame_id>
filename="gz-sim-joint-state-publisher-system"
name="gz::sim::systems::JointStatePublisher">
<!-- <plugin
filename="gz-sim-pose-publisher-system"
name="gz::sim::systems::PosePublisher">
<publish_link_pose>true</publish_link_pose>
<publish_nested_model_pose>true</publish_nested_model_pose>
<use_pose_vector_msg>true</use_pose_vector_msg>
<static_publisher>true</static_publisher>
<static_update_frequency>1</static_update_frequency>
filename="gz-sim-odometry-publisher-system"
name="gz::sim::systems::OdometryPublisher">
<dimensions>3</dimensions>
</plugin> -->
Appreciate any help!
