Dear reader,
I want to migrate an existing plugin for a vacuum gripper from Gazebo-classic to Gazebo Harmonic. I have created a CMakeLists.txt for this:
cmake_minimum_required(VERSION 3.8)
project(ros_industrial_actuators)
cmake_minimum_required(VERSION 3.10.2 FATAL_ERROR)
# Find dependencies
find_package(ament_cmake REQUIRED)
find_package(ament_cmake_python REQUIRED)
# Find gz-cmake
find_package(gz-cmake3 REQUIRED)
# Find gz-common
gz_find_package(gz-common5
COMPONENTS profiler
REQUIRED)
set(GZ_COMMON_VER ${gz-common5_VERSION_MAJOR})
# Find gz-plugin
gz_find_package(gz-plugin2 REQUIRED COMPONENTS register)
set(GZ_PLUGIN_VER ${gz-plugin2_VERSION_MAJOR})
# Find gz-msgs
gz_find_package(gz-msgs10 REQUIRED)
set(GZ_MSGS_VER ${gz-msgs10_VERSION_MAJOR})
# Find gz-sim
gz_find_package(gz-sim8 REQUIRED)
set(GZ_SIM_VER ${gz-sim8_VERSION_MAJOR})
# Configure the project
set(CMAKE_CXX_STANDARD 17)
set(CMAKE_CXX_STANDARD_REQUIRED ON)
#gz_configure_project(VERSION_SUFFIX)
# Set project-specific options
set (DRI_TESTS TRUE CACHE BOOL "True to enable DRI tests")
option(ENABLE_PROFILER "Enable Gazebo Profiler" FALSE)
if(ENABLE_PROFILER)
add_definitions("-DGZ_PROFILER_ENABLE=1")
else()
add_definitions("-DGZ_PROFILER_ENABLE=0")
endif()
add_library(VacuumGripper vacuum_gripper/VacuumGripper.cc)
set_property(TARGET VacuumGripper PROPERTY CXX_STANDARD 17)
target_link_libraries(VacuumGripper
PRIVATE
gz-common${GZ_COMMON_VER}::gz-common${GZ_COMMON_VER}
gz-plugin${GZ_PLUGIN_VER}::gz-plugin${GZ_PLUGIN_VER}
gz-sim${GZ_SIM_VER}::gz-sim${GZ_SIM_VER}
install(TARGETS
VacuumGripper
DESTINATION lib/${PROJECT_NAME}
install(TARGETS
ARCHIVE DESTINATION lib
LIBRARY DESTINATION lib
RUNTIME DESTINATION bin
# Install models
install(DIRECTORY models
DESTINATION share/${PROJECT_NAME}/
# Install launch
install(DIRECTORY launch
# Python package installation
ament_python_install_package(${PROJECT_NAME})
# Python installation
install(PROGRAMS
ros_industrial_actuators/vacuum_gripper.py
launch
# Install package.xml
install(FILES package.xml
ament_package()
The CMakeLists.txt is compiled correctly.
I have also created a model.sdf file:
<?xml version="1.0"?>
<sdf version="1.6">
<model name="vacuum_gripper">
filename="VacuumGripper"
name="vacuum_gripper::VacuumGripper">
When loading the vacuum_gripper.sdf the following error message is given:
[gazebo-5] [Err] [SystemLoader.cc:92] Failed to load system plugin [VacuumGripper] : Could not find shared library.
Unfortunately I am unable to fill in the CMakeLists.txt correctly.
I used Gazebo Sim: Create System Plugins as a reference for this plugin.
Who can help me with this? Thanks in advance for your answer.
Gerard
