The plugin changes properties but does not render
Hello gazebo community,
I want to create a plugin responsible for light animations. I made a simple plugin based on the examples. However, I encountered a strange behavior where the value of an object’s property changes, but this does not translate into the visualizations. Any ideas?
gz_lights
Code for reproduction:
C++
#include "SampleSystem.hh"
#include <gz/plugin/Register.hh>
#include <random>
#include "gz/sim/components/LightCmd.hh"
SampleSystem::SampleSystem() : gz::sim::System()
SampleSystem::~SampleSystem()= default;
void SampleSystem::Configure(const gz::sim::Entity &_entity,
    const std::shared_ptr<const sdf::Element> &_sdf,
    gz::sim::EntityComponentManager &_ecm,
    gz::sim::EventManager &_eventMgr)
  this->entity = _entity;
  ignmsg << "Command actor for entity [" << _entity << "]" << std::endl;
  // Iterate through entities to find the light entity by name
  _ecm.Each<gz::sim::components::Name, gz::sim::components::Light>(
      [&](const gz::sim::Entity &_entity,
          const gz::sim::components::Name *_name,
          const gz::sim::components::Light *) -> bool
        if (_name->Data() == "frontlight")
          this->lightEntity = _entity;
          ignmsg << "Light entity found: " << this->lightEntity << std::endl;
          return true; // Stop searching
        return true;
  if (this->lightEntity == gz::sim::kNullEntity)
      std::cerr << "Error: Light entity not found." << std::endl;
      return;
  this->lastUpdateTime = std::chrono::steady_clock::now();
void SampleSystem::PreUpdate(
    const gz::sim::UpdateInfo &_info,
    gz::sim::EntityComponentManager &_ecm)
    auto currentTime = std::chrono::steady_clock::now();
    if (currentTime - this->lastUpdateTime >= std::chrono::seconds(1))
        // Retrieve the light component
        static auto lightComp = _ecm.Component<gz::sim::components::Light>(this->lightEntity);
        if (!lightComp)
            ignerr << "Error: Light component not found on light entity: " << this->lightEntity << std::endl;
            return;
        // Generate random RGB values
        double r = this->distribution(this->generator);
        double g = this->distribution(this->generator);
        double b = this->distribution(this->generator);
        // Create new light with random color
        sdf::Light newLight = lightComp->Data();
        newLight.SetDiffuse(gz::math::Color(r, g, b, 1));
        newLight.SetSpecular(gz::math::Color(r, g, b, 1));
        // Update the light component
        *lightComp = gz::sim::components::Light(newLight);
        _ecm.SetChanged(
            this->lightEntity,
            gz::sim::components::Light::typeId,
            gz::sim::ComponentState::PeriodicChange
        this->lastUpdateTime = currentTime;
IGNITION_ADD_PLUGIN(SampleSystem,
    gz::sim::System,
    SampleSystem::ISystemConfigure,
    SampleSystem::ISystemPreUpdate)
H++
#ifndef SYSTEM_PLUGIN_SAMPLESYSTEM_HH_
#define SYSTEM_PLUGIN_SAMPLESYSTEM_HH_
#include <chrono>
#include <gz/sim/System.hh>
#include <gz/sim/components/Light.hh>
#include <gz/sim/components/Material.hh>
#include <gz/sim/components/Visual.hh>
#include <gz/sim/components/Name.hh>
#include <gz/sim/EntityComponentManager.hh>
#include <gz/sim/EventManager.hh>
#include <gz/sim/rendering/Events.hh>
#include <gz/common/Timer.hh>
#include <sdf/Pbr.hh>
// class UserCommandsPrivate;
class SampleSystem:
  public gz::sim::System,
  public gz::sim::ISystemConfigure,
  public gz::sim::ISystemPreUpdate
  public: SampleSystem();
  public: ~SampleSystem() final;
  public: void Configure(const gz::sim::Entity &_id,
                          gz::sim::EventManager &_eventMgr) final;
  public: void PreUpdate(const gz::sim::UpdateInfo &_info,
              gz::sim::EntityComponentManager &_ecm) override;
  private:
    gz::sim::Entity entity;
    gz::sim::Entity visualEntity{gz::sim::kNullEntity};
    gz::sim::Entity lightEntity{gz::sim::kNullEntity};
    std::chrono::steady_clock::time_point lastUpdateTime;
    std::default_random_engine generator;
    std::uniform_real_distribution<double> distribution{0.0, 1.0};
    // std::unique_ptr<UserCommandsPrivate> dataPtr;
#endif
SDF
<?xml version="1.0" ?>
<sdf version="1.6">
  <world name="default">
    <physics name="fast" type="ignored">
      <max_step_size>0.001</max_step_size>
      <real_time_factor>0</real_time_factor>
    </physics>
      filename="ignition-gazebo-physics-system"
      name="gz::sim::systems::Physics">
      filename="ignition-gazebo-user-commands-system"
      name="gz::sim::systems::UserCommands">
      filename="ignition-gazebo-scene-broadcaster-system"
      name="gz::sim::systems::SceneBroadcaster">
      filename="ignition-gazebo-contact-system"
      name="gz::sim::systems::Contact">
    <light type="directional" name="sun">
      <cast_shadows>true</cast_shadows>
      <pose>0 0 10 0 0 0</pose>
      <diffuse>0.8 0.8 0.8 1</diffuse>
      <specular>0.2 0.2 0.2 1</specular>
      <attenuation>
        <range>1000</range>
        <constant>0.9</constant>
        <linear>0.01</linear>
        <quadratic>0.001</quadratic>
      </attenuation>
      <direction>-0.5 0.1 -0.9</direction>
    </light>
    <model name="ground_plane">
      <plugin filename="SampleSystem" name="SampleSystem"/>
      <link name="light">
        <pose>0 0 0.1 0 0 0</pose>
        <light name="frontlight" type="spot">
          <visualize>0</visualize>
          <diffuse>1.0 1.0 0.0</diffuse>
          <specular>1.0 1.0 0.0</specular>
          <direction>1 0 0</direction>
          <intensity>1.0</intensity>
          <spot>
            <inner_angle>1.0</inner_angle>
            <outer_angle>2.0</outer_angle>
            <falloff>0.4</falloff>
          </spot>
        </light>
            <plane>
              <normal>0 0 1</normal>
              <size>100 100</size>
            </plane>
            <plane>
            </plane>
            <ambient>0.8 0.8 0.8 1</ambient>
            <specular>0.8 0.8 0.8 1</specular>
  </world>
maybe its too fast for humans eyes
The frequency is 1Hz. It looks more like a rendering step is missing. I’m not sure if it’s possible to run it somehow for SystemPlugin. Maybe I should use GuiPlugin.
Edit: I convert code to GuiPlugin but right now colors changes but properties not, so it still looks weird.
Hi @Rafal_Gorecki
You should use the LightCmd component for modifying these properties. Better yet, you can use the gz::sim::Light class that encapsulates a lot of what you’re doing.
Hi @azeey,
Thanks for your support, it works fine after using LightCMD. I don’t know how to change it though
the gz::sim::Light class. When I set followin code in PreUpdate function nothing change:
gz::sim::Light light(light_entity);
light.SetDiffuseColor(ecm, gz::math::Color(1.0, 0.0, 0.0, 0.0));
light.SetSpecularColor(ecm, gz::math::Color(1.0, 0.0, 0.0, 0.0));
lights_entity is taken from:
    const gz::sim::Entity & entity, const gz::sim::components::Name * name,
    const gz::sim::components::Light *) -> bool {
    if (name->Data() == light_name) {
      light_entity = entity;
      return true;
running the plugin doesn’t cause any changes. Do I still need to confirm the changes somehow similar to ecm.SetChanged()? Or is there a demo showing how to use wrappers?
It appears that if I execute multiple Set* operations, only the last one gets executed.
I think this is a bug. I’ve created an issue: https://github.com/gazebosim/gz-sim/issues/2532. The Gazebo developers are pretty busy getting ready for the Ionic release, so this will probably not get fixed anytime soon. However, if you want to work on a fix, we’d gladly accept pull requests.
