I need your help with getting Ignition Fortress (LTS) up and running. I have Noble Numbat (Ubuntu 24.04) and ROS2 (Rolling Ridley) running. However, attempting the binary installation of Ignition Fortress (LTS) on Ubuntu returns an error message: “Unable to locate package ignition-fortress.”
My Ubuntu is installed on Windows 11 using WSL. I am new to the world of Robotics and simulations.
Thank you for this information. I worked on this by installing the Jammy-Rolling-Fortress combo. Initially, I encountered the message “QStandardPaths: wrong permissions on runtime directory /run/user/1000/, 0755 instead of 0700” on running the “ign gazebo” command. Gazebo came up with an empty dark screen. I was able to resolve the QStandardPaths message with “chmod 0700 /run/user/1000/”, but the empty black gazebo screen issue remains. Once again, thank you for you help.
I resolved the issue of empty dark screen by running export LIBGL_ALWAYS_SOFTWARE=1. I understand that this forces software rendering. This line has to be run every time Gazebo starts in a new terminal. To make this change permanent, ensuring that the environment variable is set automatically for every terminal session, I added this line to the end of the ~/.bashrc file. Thank you @kakcalu13 and @peci1 for your helpful contributions.
