Gazebo collision not working as expected. Link penetrating and crossing the box object
I’m facing very weird problem with gazebo the robot link cross the object even though its collision and inertial properties are proper generated from Solidwork CAD Software . Why link is penetrates the box? min_depth is also zero. Friction is also quite high. Can it be some physics engine property issue?
collision_issue
World File
<?xml version="1.0" ?>
<sdf version="1.6">
  <world name="default">  <physics type="ode">
      <max_step_size>0.001</max_step_size>
      <real_time_update_rate>1000</real_time_update_rate>
      <ode>
        <solver>
          <!-- <type>world</type> -->
          <!-- <iters>50</iters>
          <sor>1.3</sor> -->
        </solver>
        <constraints>
          <cfm>0</cfm>
          <erp>0.200000</erp>
          <contact_max_correcting_vel>100.0</contact_max_correcting_vel>
          <contact_surface_layer>0.0001</contact_surface_layer>
        </constraints>
      </ode>
    </physics>
      <uri>model://sun</uri>
<model name='unit_box'>
    <pose>0.4 0.07 0.5 0 -0 0</pose>
    <link name='link'>
        <mass>0.00015774</mass>
          <ixx>0.000000433335</ixx>
          <iyy>0.000000433335</iyy>
          <izz>0.000000433335</izz>
        <pose>0 0 0 0 -0 0</pose>
      <collision name='collision'>
            <size>0.054384 0.056414 0.066751</size>
        <max_contacts>100</max_contacts>
        <surface>
          <contact>
            <ode/>
          </contact>
          <bounce/>
          <friction>
            <torsional>
              <ode/>
            </torsional>
            <ode/>
          </friction>
        </surface>
      <visual name='visual'>
          <script>
            <name>Gazebo/White</name>
          </script>
      <enable_wind>0</enable_wind>
      <kinematic>0</kinematic>
  </world>
URDF Link
<link name="palm_Link">
      <origin
        xyz="0.11195757840872 0.0218208391835557 -0.0102781634021541"
        rpy="0 0 0" />
      <mass
        value="0.0574455788604759" />
      <inertia
        ixx="2.76099031307389E-05"
        ixy="-8.29004144373025E-05"
        ixz="-1.91812265176209E-06"
        iyy="0.000324487528258486"
        iyz="2.5599393986152E-07"
        izz="0.00034583642559353" />
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
          filename="package://robot_description/meshes/palm_Link.STL" />
      <material
        name="">
        <color
          rgba="0.698039215686274 0.698039215686274 0.698039215686274 1" />
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
        <mesh
<gazebo reference="palm_Link">
    <mu1>10.0</mu1>
    <mu2>10.0</mu2>
    <kp>1e+9</kp>
    <kd>1e+9</kd>
    <selfCollide>true</selfCollide>
    <material>Gazebo/Black</material>
I"m using gazebo 11 classic and ros2 humble
