Controllers are Loaded but can't activate
my urdf file -
<?xml version="1.0"?>
<xacro:include filename="$(find arm_simulation)/urdf/robot.xacro"/>
<!-- fixing the arm to the base -->
<link name="world" />
<joint name="fixed" type="fixed">
    <parent link="world"/>
    <child link="base_link"/>
<link name="base_link">
    <visual>
            <cylinder radius="0.1" length="0.05"/>
        <origin xyz="0.0 0.0 0.025 " rpy="0.0 0.0 0.0"/>
    <collision>
<xacro:arm_link_cylinder name = "base_link" origin_xyz = "0.0 0.0 0.025" origin_rpy = "0.0 0.0 0.0"
                        radius = "0.1" length = "0.05"
                        mass = "1" ixx = "0.0001" ixy = "0" ixz ="0"
                        iyy = "0.0001" iyz = "0"
                        izz = "0.0001" />
<xacro:arm_link_cylinder name = "link_1" origin_xyz = "0.0 0.0 0.132" origin_rpy = "0.0 0.0 0.0"
                        radius = "0.05" length = "0.264"
                        mass = "1.5" ixx = "0.054147" ixy = "0" ixz ="0"
                        iyy = "0.054147" iyz = "0"
                        izz = "0.001875"
<!-- <joint name="base_link__link_1" type="revolute">
    <parent link="base_link"/>
    <child link="link_1"/>
    <axis xyz="0 0 1"/>
    <limit lower="-3.14159" upper="3.14159" velocity="0.5" effort="1000.0"/>
    <origin xyz="0 0 0.05" rpy="0 0 0"/>
</joint> -->
<xacro:arm_joint name = "base_link__link_1" type = "revolute" parent = "base_link" child = "link_1"
                        axis = "0 0 1" lower_limit = "-3.14" upper_limit = "3.14"
                        vel_limit = "0.5" eff_limit = "1000.0"
                        origin_xyz = "0 0 0.05" origin_rpy = "0 0 0"
<xacro:arm_link_cylinder name = "link_2" origin_xyz = "0.0 0.0 0.425" origin_rpy = "0.0 0.0 0.0"
                        radius = "0.05" length = "0.85"
                        mass = "2" ixx = "0.12167" ixy = "0" ixz ="0"
                        iyy = "0.12167" iyz = "0"
                        izz = "0.0025"
<xacro:arm_joint name = "link_1__link_2" type = "revolute" parent = "link_1" child = "link_2"
                        axis = "0 1 0" lower_limit = "-3.14" upper_limit = "2.5"
                        origin_xyz = "0 0.1 0.214" origin_rpy = "0 0 0"
<!-- <xacro:arm_link_cylinder name = "link_3" origin_xyz = "0.0 0.0 0.34" origin_rpy = "0.0 0.0 0.0"
                        radius = "0.05" length = "0.68"
                        mass = "2" ixx = "0.07832" ixy = "0" ixz ="0"
                        iyy = "0.07832" iyz = "0"
                        izz = "0.0025"
<xacro:arm_joint name = "link_2__link_3" type = "revolute" parent = "link_2" child = "link_3"
                        axis = "0 1 0" lower_limit = "-3.14" upper_limit = "3.14"
                        origin_xyz = "0 -0.1 0.8" origin_rpy = "0 0 0"
<xacro:arm_link_cylinder name = "link_4" origin_xyz = "0.0 0.0 0.065" origin_rpy = "0.0 0.0 0.0"
                        radius = "0.05" length = "0.13"
                         mass = "1" ixx = "0.00565" ixy = "0" ixz ="0"
                        iyy = "0.0" iyz = "0"
                        izz = "0.00565"
<xacro:arm_joint name = "link_3__link_4" type = "revolute" parent = "link_3" child = "link_4"
                        origin_xyz = "0 -0.1 0.638" origin_rpy = "0 0 0"
<xacro:arm_link_cylinder name = "link_5" origin_xyz = "0.0 0.0 0.035" origin_rpy = "0.0 0.0 0.0"
                        radius = "0.05" length = "0.17"
                         mass = "2" ixx = "0.4816" ixy = "0" ixz ="0"
                        izz = "0.4816"
<xacro:arm_joint name = "link_4__link_5" type = "revolute" parent = "link_4" child = "link_5"
                        axis = "1 0 0" lower_limit = "-3.14" upper_limit = "3.14"
                        origin_xyz = "0 0.0 0.180" origin_rpy = "0 1.57 0"
<!-- end effector config  -->
<!-- <xacro:arm_link_box name = "tcp_connector" size = "0.03 0.15 0.03"
                    origin_xyz = "0.0 0.0 0.0125" origin_rpy = "0.0 0.0 0.0"
                    mass = "1" ixx = "0.00195" ixy = "0" ixz ="0"
                    iyy = "0.00195" iyz = "0"
                    izz = "0.00015"
<xacro:arm_joint name = "link_5__tcp_connector" type = "revolute" parent = "link_5" child = "tcp_connector"
                        origin_xyz = "0 0.0 0.120" origin_rpy = "0 0 0"
<xacro:arm_link_box name = "gripper_right" size = "0.01 0.01 0.1"
                    origin_xyz = "0.0 0.0 0.05" origin_rpy = "0.0 0.0 0.0"
                    mass = "0.5" ixx = "0.00042" ixy = "0" ixz ="0"
                    iyy = "0.00042" iyz = "0"
                    izz = "0.0000083"
<xacro:arm_joint name = "tcp_connector_gripper_right" type = "prismatic" parent = "tcp_connector" child = "gripper_right"
                        axis = "0 1 0" lower_limit = "0" upper_limit = "0.055"
                        origin_xyz = "0 -0.065 0.03" origin_rpy = "0 0 0"
<xacro:arm_link_box name = "gripper_left" size = "0.01 0.01 0.1"
                    izz = "0.0000083"
<xacro:arm_joint name = "tcp_connector_gripper_left" type = "prismatic" parent = "tcp_connector" child = "gripper_left"
                        axis = "0 1 0" lower_limit = "0" upper_limit = "-0.055"
                        origin_xyz = "0 0.065 0.03" origin_rpy = "0 0 0"
<!-- transmission in every joint -->
<xacro:transmission name = "transmission_base_link__link_1"
                    joint_name = "base_link__link_1"
                    actuator_name = "motor_base_link__link_1" />
<xacro:transmission name = "transmission_link_1__link_2"
                    joint_name = "link_1__link_2"
                    actuator_name = "motor_link_1__link_2" />
<!-- <xacro:transmission name = "transmission_link_2_link_3"
                    joint_name = "link_2__link_3"
                    actuator_name = "motor_link_2__link_3" />
<xacro:transmission name = "transmission_link_3__link_4"
                    joint_name = "link_3__link_4"
                    actuator_name = "motor_link_3__link_4" />
<xacro:transmission name = "transmission_link_4__link_5"
                    joint_name = "link_4__link_5"
                    actuator_name = "motor_link_4__link_5" />
<xacro:transmission name = "transmission_link_5__tcp_connector"
                    joint_name = "link_5__tcp_connector"
                    actuator_name = "link_5__tcp_connector" />
<xacro:transmission name = "transmission_tcp_connector_gripper_right"
                    joint_name = "tcp_connector_gripper_right"
                    actuator_name = "tcp_connector_gripper_right" />
<xacro:transmission name = "transmission_tcp_connector_gripper_left"
                    joint_name = "tcp_connector_gripper_left"
                    actuator_name = "tcp_connector_gripper_left" /> -->
<!--  creating gazebo plugin -->
<gazebo>
    <plugin filename="libgz_ros2_control-system" name="gz_ros2_control::GazeboSimROS2ControlPlugin">
        <parameters>$(find arm_simulation)/config/joint_controller.yaml</parameters>
        <controller_manager_name>controller_manager</controller_manager_name>
<ros2_control name="GazeboSystem" type="system">
    <hardware>
        <plugin>gz_ros2_control/GazeboSystem</plugin>
    </hardware>
    <joint name="base_link__link_1">
        <command_interface name="position">
            <param name="min">-3.14</param>
            <param name="max">3.14</param>
        </command_interface>
        <state_interface name="position">
            <param name="initial_value">0.0</param>
        </state_interface>
        <state_interface name="velocity">
        </state_interface>
    <joint name="link_1__link_2">
        </state_interface>
        </state_interface>
</ros2_control>
My launch file-
import os
from ament_index_python.packages import get_package_share_directory
from launch import LaunchDescription
from launch.actions import DeclareLaunchArgument, IncludeLaunchDescription
from launch.launch_description_sources import PythonLaunchDescriptionSource
from launch.substitutions import LaunchConfiguration, Command
from launch_ros.actions import Node
import yaml
def generate_launch_description():
    # sourcing the paths for the packages
    arm_simulation_pkg_share = get_package_share_directory('arm_simulation')
    gazebo_ros_pkg_share = get_package_share_directory('ros_gz_sim')
# sourcing the urdf and controller file
urdf_file_path = os.path.join(arm_simulation_pkg_share, 'urdf', 'arm.urdf')
controller_file_path = os.path.join(arm_simulation_pkg_share, 'config', 'joint_controller.yaml')
# loading the controllers from the yaml file
with open(controller_file_path, 'r') as file:
    controller_params = yaml.safe_load(file)
# Spawning the robot at the given coordinates
x_space = DeclareLaunchArgument(
    'x',
    default_value='0.0',
y_space = DeclareLaunchArgument(
    'y',
z_space = DeclareLaunchArgument(
    'z',
# specifying the gazebo arguments
declare_sim_time = DeclareLaunchArgument(
    'use_sim_time',
    default_value='true',
declare_debug = DeclareLaunchArgument(
    'debug',
    default_value='false',
declare_gui = DeclareLaunchArgument(
    'gui',
declare_paused = DeclareLaunchArgument(
    'paused',
robot_description_content = Command([
    'xacro ',
    urdf_file_path
robot_description_param = {'robot_description': robot_description_content }
# 4. Launch Gazebo empty world
gazebo_launch = IncludeLaunchDescription(
    PythonLaunchDescriptionSource(ymal
        os.path.join(
            gazebo_ros_pkg_share,
            'launch',
            'gz_sim.launch.py'
    launch_arguments={
        'gz_args': os.path.join(gazebo_ros_pkg_share, 'worlds', 'empty.sdf'),
        'use_sim_time': LaunchConfiguration('use_sim_time'),
        'debug': LaunchConfiguration('debug'),
        'gui': LaunchConfiguration('gui'),
        # 'paused': LaunchConfiguration('paused')
    }.items()
# 5 Loading the controller files
# Calling nodes
robot_state_publisher_node = Node(
    package='robot_state_publisher',
    executable='robot_state_publisher',
    name='robot_state_publisher',
    parameters=[
        robot_description_param,
        {'use_sim_time': LaunchConfiguration('use_sim_time')}
spawn_robot_node = Node(
    package='ros_gz_sim',
    executable='create',
    name='spawn_the_robot',
    output='screen',
    arguments=[
        '-topic','robot_description',
        '-entity', 'arm',
        '-x', LaunchConfiguration('x'),
        '-y', LaunchConfiguration('y'),
        '-z', LaunchConfiguration('z'),
    parameters=[
# controller_manager_node = Node(
#     package = 'controller_manager',
#     executable = 'ros2_control_node',
#     output = 'both',
#     parameters= [
#         robot_description_param,
#         controller_params,
#         {'use_sim_time': LaunchConfiguration('use_sim_time')}
# adding each joint nodes for individual controller
robot_controller_name = [
    'joint_state_broadcaster',
    'joint1_position_controller',
    'joint2_position_controller'
spawner_nodes = [
    Node(
        package="controller_manager",
        executable="spawner",
        output="screen",
        arguments=[
            controllers,
            '--controller-manager',
            "/controller_manager",
    ) for controllers in robot_controller_name
return LaunchDescription([
    x_space,
    y_space,
    z_space,
    declare_sim_time,
    declare_debug,
    declare_gui,
    declare_paused,
    gazebo_launch,
    robot_state_publisher_node,
    spawn_robot_node,
    # controller_manager_node,
    *spawner_nodes
my .yaml file -
controller_manager:
  ros__parameters:
    update_rate: 100
    use_sim_time: true
    joint_state_broadcaster:
      type: joint_state_broadcaster/JointStateBroadcaster
    joint1_position_controller:
      type: forward_command_controller/ForwardCommandController
    joint2_position_controller:
  ros__parameters:
    joints:
      - base_link__link_1
      - link_1__link_2
  ros__parameters:
    joint:
     - base_link__link_1
    command_interfaces:
      - position
    state_interfaces:
      - position
    gains:
      base_link__link_1:
        p: 100.0
        i: 0.0
        d: 10.0
  ros__parameters:
    joint:
      - link_1__link_2
    command_interfaces:
      - position
    state_interfaces:
      - position
    gains:
      link_1__link_2:
        p: 100.0
        i: 0.0
        d: 10.0
I am using ROS2 Humble with gazebo Ignition along with Ubuntu 22.04. I am not able to activate my controller i tried everything. I made a custom UR5 robot..
i really appreciate the help.
